Front Suspension recomendations |
rcampbell2909 |
Jun 22 2019, 09:10 PM
Newbie Group: Members Posts: 6 Joined: 24-November 16 From: Columbiana, Ohio Member No.: 20,617 Region Association: North East States |
Hello all,
I have done some searching and have not come up with much for recent results to guide me in a direction to make a decision in improving my front suspension. This question is in regard to a '75. I need to replace my front struts as one is leaking oil and the other seems to have no resistance left at this point. I have been running with the front around 3" lower than stock height (adjusted using the small bolt on the torsion bars). I wanted to consider any upgrades/changes while I will be changing the struts. Should I be looking at other options to lower the front? I was shopping for struts and noticed that there is a "sport" strut in the Bilstein line to be used with lowered springs-but I have not found the springs to match... What are my best options at this point? Just replace the struts and continue to run with the adjusters where they are for ride height? Explore lowering springs? Other options? Is there anything else I should be doing while I am in there replacing struts? Also, what is the current thought on the various struts that are available. I see a variety I see Bilsteins, Sachs, Boge, etc... This is a street car with a large stroker 4 cylinder, but will not see much if any track time. Thank you for any assistance that can be offered. |
roblav1 |
Jun 23 2019, 08:03 AM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
3" lowered is Way too low! You probably bottomed the struts too many times and killed them.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:36 AM |
