Cover for hole under Gas Tank and Seal around Steering column?, Wondering what fills the hole and gap |
sketchc13 |
Jun 5 2019, 10:12 AM
Newbie Group: Members Posts: 13 Joined: 7-February 11 From: NorCal Member No.: 12,675 Region Association: Northern California |
I have my gas tank out and under it there is a ~100mm hole on the passenger side and a gap around the boot where the steering column goes through the body on the way to the steering rack.
Is something missing? Coming from Wisconsin, the hole and gap are very inviting to garage invading squirrels to store their nuts and more in the fall and winter and it seems like something should go there.... Are there OE parts that go there or did any one fab something up for the hole and gap? See attached pic... I have since cleaned up the surface rust. Cheers, Andrew |
Spoke |
Jun 11 2019, 05:45 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I welded up the hole for access to the fuel tank lines. Not needed if an extra 3 feet of hose is added to loop under the tank. Now no need to drain the tank to pull it out.
Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
Jun 23 2019, 09:35 AM
914 Wiring Harnesses Group: Members Posts: 8,524 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I welded up the hole for access to the fuel tank lines. Not needed if an extra 3 feet of hose is added to loop under the tank. Now no need to drain the tank to pull it out. You will regret that. Obviously the access hole is there to connect the fuel lines. Folks here who have thought they were clever by adding 3 feet to the fuel lines quickly discover that the extra length easily kinks and cuts off fuel flow. Then they pull out the tank...again...and go back to short lines as originally designed. And trying to lift a tank with fuel in it is much harder than when its empty. |
Lo-Fi Version | Time is now: 1st June 2024 - 05:49 PM |
