| brainf18 |
Jun 8 2019, 04:26 PM
Newbie ![]() Group: Members Posts: 19 Joined: 12-May 19 From: Louisville KY Member No.: 23,116 Region Association: None |
I was looking for a set of 6.5x15 steel wheels for track days. I wanted to run 205/15's all the way around. Wasn't able to find any low cost "off the shelf" solutions for an unmodified 4x130 bold pattern. So I settled on 5.5in wheels and ordered a set from Sierra Madre Classics. ($59 each)
When the wheels arrived, they looks suspiciously larger than 5.5 inchs. So I put a tape measure on them and to my surprise they were just a few mils under 6.5 inches wide. I test mounted this morning and the backspacing and offset were spot on. Problem solved. Though others might like to know... https://sierramadrecollection.com/Steel-Whe...1-2-p19583.html [/url] |
| Mark Henry |
Jun 23 2019, 08:17 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
You could make your own in 15x7"
Grind the welds out of a set of old wheels for the centers, buy a set of barrels and weld them in. A hub and a lathe with a big enough swing would make the lay-up job easy. I did the 24" front wheels on my tractor with just a straightedge and a caliper and it runs straight, mounting/measuring on a lathe will be very accurate. When I bought my barrels 15x7" were available. |
brainf18 6.5x15 Steel'ies Jun 8 2019, 04:26 PM
michael7810 I don’t know how to measure wheels but those are... Jun 8 2019, 04:49 PM
porschetub :agree: its done on the inside where the tyre moun... Jun 8 2019, 04:58 PM
brainf18
:agree: its done on the inside where the tyre mou... Jun 8 2019, 05:49 PM
porschetub
:agree: its done on the inside where the tyre mou... Jun 8 2019, 07:51 PM
mark04usa Sure is a fine looking steely, though. Haven't... Jun 8 2019, 05:35 PM
DickSteinkamp Wheels are measured inside to inside of the bead. ... Jun 8 2019, 05:52 PM
Wheels are measured inside to inside of the bead.... Jun 8 2019, 06:01 PM
brainf18
Wheels are measured inside to inside of the bead.... Jun 8 2019, 06:46 PM
michael7810 I run 205s on my 2L Fuchs and they are 5.5s. 30K m... Jun 8 2019, 07:08 PM
chrisg What do they weigh? I assume all steelies of simil... Jun 8 2019, 08:01 PM
brainf18
What do they weigh? I assume all steelies of simi... Jun 8 2019, 09:08 PM
80’s old school Have you mounted these up yet? I want to see what... Jun 23 2019, 07:19 PM
sixnotfour Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x ... Jun 24 2019, 03:28 PM
IronHillRestorations
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x... Jun 24 2019, 06:56 PM
80’s old school
Wheel, OEM VW, Steel, Silver, 15 in. x 6 in., 4 x... Jun 24 2019, 10:10 PM
IronHillRestorations I was wrong. 7" 911R wheels will go on the b... Jun 24 2019, 07:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:29 AM |
