| BiG bOgGs |
Jun 24 2019, 02:51 PM
The Bogus One ![]() ![]() Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States |
I’m getting ready to put my front suspension back together, but I don’t have the tool to press the bushings on. Would anyone direct me to one of our vendors that sells the tool?
Jim |
| iankarr |
Jun 24 2019, 08:52 PM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,611 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
I tried the bar clamp method without success. If your bushings are URO, maybe they'll be a bit softer and looser.
Full disclosure: I shot the bushing install video for 914 Rubber (in my link below) and, I'm clearly biased about their quality. That said, believe me when I say this isn't a job you want to do twice. Use the best bushings you can afford. There's also a really good chance you'll trash a bushing or three till you get them installed correctily. 914Rubber will take back any uninstalled bushings with no restocking fee...so you can get a few spares and not hold up your project. Of course, I understand not wanting to lay out more $$ for something you already have. As Kent mentioned, there are definitely ways to install without a special tool. Very cool that John will lend you the tools. This community is amazing. Whatever you decide, good luck and be safe! |
| bdstone914 |
Jun 25 2019, 08:41 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,422 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I tried the bar clamp method without success. If your bushings are URO, maybe they'll be a bit softer and looser. Full disclosure: I shot the bushing install video for 914 Rubber (in my link below) and, I'm clearly biased about their quality. That said, believe me when I say this isn't a job you want to do twice. Use the best bushings you can afford. There's also a really good chance you'll trash a bushing or three till you get them installed correctily. 914Rubber will take back any uninstalled bushings with no restocking fee...so you can get a few spares and not hold up your project. Of course, I understand not wanting to lay out more $$ for something you already have. As Kent mentioned, there are definitely ways to install without a special tool. Very cool that John will lend you the tools. This community is amazing. Whatever you decide, good luck and be safe! #cuddy_k @BiG bOgGs (IMG:style_emoticons/default/agree.gif) Uro bushing are inconsistant and too soft overall. Don't use them. Uro claims to have a sport grade bushing which might be an attempt to fix the softer than stock ones they started with. No specs as usual from them. Use a piece of 5/8" or larger thread-all and pull them on one at a time. Look at Ian's video. I too ground the bar clamp a poor choice. It take heat and lube on the bushings to install them correctly. Even with the tools it is easy for them to pull crooked and catch and tear on the sharpe corners of the rear of the trailing arm. I have done it several times even with the 914 Rubber bushings. |
| Mikey914 |
Jun 25 2019, 10:04 AM
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,786 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None
I tried the bar clamp method without success. If your bushings are URO, maybe they'll be a bit softer and looser. Full disclosure: I shot the bushing install video for 914 Rubber (in my link below) and, I'm clearly biased about their quality. That said, believe me when I say this isn't a job you want to do twice. Use the best bushings you can afford. There's also a really good chance you'll trash a bushing or three till you get them installed correctily. 914Rubber will take back any uninstalled bushings with no restocking fee...so you can get a few spares and not hold up your project. Of course, I understand not wanting to lay out more $$ for something you already have. As Kent mentioned, there are definitely ways to install without a special tool. Very cool that John will lend you the tools. This community is amazing. Whatever you decide, good luck and be safe! #cuddy_k @BiG bOgGs (IMG:style_emoticons/default/agree.gif) Uro bushing are inconsistant and too soft overall. Don't use them. Uro claims to have a sport grade bushing which might be an attempt to fix the softer than stock ones they started with. No specs as usual from them. Use a piece of 5/8" or larger thread-all and pull them on one at a time. Look at Ian's video. I too ground the bar clamp a poor choice. It take heat and lube on the bushings to install them correctly. Even with the tools it is easy for them to pull crooked and catch and tear on the sharpe corners of the rear of the trailing arm. I have done it several times even with the 914 Rubber bushings. Yes this is not an easy job, it is very easy to destroy a bushing. There is a learning curve. You need to be fast, but you also need to accurate in driving these on. Mark |
BiG bOgGs Bushing install tool. Jun 24 2019, 02:51 PM
mepstein 914rubber has them
@Mikey914 Jun 24 2019, 03:34 PM
BiG bOgGs
914rubber has them
[b]@[url=http://www.914world... Jun 24 2019, 03:57 PM
rhodyguy Unfortunate...but I get why. As it's an instal... Jun 24 2019, 04:19 PM
76-914 It's not that difficult. I did mine before I k... Jun 24 2019, 04:47 PM
BiG bOgGs
It's not that difficult. I did mine before I ... Jun 24 2019, 06:18 PM
Geezer914 Get some all thread, nuts, washers, and pieces of ... Jun 24 2019, 05:44 PM
Larmo63 Bruce Stone has the tool. Get in touch with him an... Jun 24 2019, 06:02 PM
johnlush If these are the same tools used for the Elephant ... Jun 24 2019, 06:06 PM
johnlush Just to clarify, here's what I have. Is this w... Jun 24 2019, 07:32 PM
BiG bOgGs
Just to clarify, here's what I have. Is this ... Jun 24 2019, 07:39 PM
johnlush Sent you a PM... Let me know where to mail them. ... Jun 24 2019, 07:41 PM
914Toy You will need a bar clamp that opens up to at leas... Jun 24 2019, 07:55 PM
Larmo63 I used Elephant Racing bushings, borrowed Bruce... Jun 24 2019, 09:13 PM
cuddy_k
I used Elephant Racing bushings, borrowed Bruce... Jun 24 2019, 09:36 PM
cuddy_k Thanks, Bruce. Nice to have some company on the sp... Jun 25 2019, 09:10 AM
rhodyguy Glycerin. Copious amounts. Jun 25 2019, 09:13 AM
Larmo63 Now this thing steers straight and with with no sq... Jun 25 2019, 10:31 AM
jmitro a true shop press helps a ton LOL
seriously.
I a... Jun 25 2019, 04:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 04:52 PM |
