Test cold start valve, tips to testing CSV before I replace it |
Fatboy007 |
Jun 24 2019, 08:02 PM
Member Group: Members Posts: 62 Joined: 23-May 17 From: San Diego, ca. Member No.: 21,124 Region Association: Southern California |
Looking for tips on how to test the CSV before I spend $$ to replace it how do i know it's bad...And best way to get those two Flat-Head screws outta there if I have to replace it. Thank you (IMG:style_emoticons/default/biggrin.gif)
ndfrigi |
Jun 24 2019, 08:16 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
direct 12 volts. maybe attach a rubber hose on one end to blow air to test the flow. After applying 12 volts, the element inside should get warm/heat and makes the valve close. when cold and blow air on one side, you should feel the air from the other side. offcourse when valve close, you can feel lesser air (i think not totally close but u will notice less air)
jim_hoyland |
Jun 24 2019, 08:29 PM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
direct 12 volts. maybe attach a rubber hose on one end to blow air to test the flow. After applying 12 volts, the element inside should get warm/heat and makes the valve close. when cold and blow air on one side, you should feel the air from the other side. offcourse when valve close, you can feel lesser air (i think not totally close but u will notice less air) Ah...this tests the AAR, not the CSV. |
ndfrigi |
Jun 25 2019, 10:49 AM
direct 12 volts. maybe attach a rubber hose on one end to blow air to test the flow. After applying 12 volts, the element inside should get warm/heat and makes the valve close. when cold and blow air on one side, you should feel the air from the other side. offcourse when valve close, you can feel lesser air (i think not totally close but u will notice less air) Ah...this tests the AAR, not the CSV. ooops yup ur correct Jim. Sorry Stacey! when I read ur thread, it just went to my mind about CSV and not AAR. My bad! huhuhu |
Lo-Fi Version | Time is now: 10th June 2024 - 01:42 PM |
