Straighten a bent trailing arm?, Can't align to within spec, Driver's rear measures bent |
rnellums |
Jun 14 2019, 10:23 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
Hey all,
I've got some issues aligning my flared 914. With the drivers rear at the limit of travel I'm still quite a bit toe out. Measurements of the hub-pivot distance are a bit longer on the drivers vs. the passenger rear. the bend isn't visually noticeable, but its there. Has anyone had luck trueing it up or should I just find another trailing arm and move on? Thanks! -Ross |
doug_b_928 |
Jun 29 2019, 09:17 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Further to the posts above, can anyone provide the procedure and measurements for checking their trailing arms? I need to check mine prior to restoring them (or replacing if they are bent).
Lo-Fi Version | Time is now: 8th June 2024 - 07:45 PM |
