> Chris Foley's Tangerine Racing shift linkage kit
Geezer914
post Jun 28 2012, 08:46 AM
Geezer914
I just finished installing Chris Foley's shift linkage kit. The car shifts smooth as silk like a normal car with a 5 speed. It's like night and day! There is no question what gear you are shifting into, the shifts are solid and tight. I first replaced all the bushings using the stock shifter. It was like "what gear am I going to find now?" It would grind going into 1st and my arm was hurting from pushing the shifter as hard as I could to the right to find 4th and 5th, and when shifting into 5th, finding 3rd instead! So I installed a Renn shifter, a little better, but not much. Was not happy. So I sprung for Chris's linkage kit and firewall bearing kit. The car is a pleasure to drive. Thanks Chris for a super engineering job and a high quality kit. If you are not happy with the way your car is shifting, I would highly recommend installing this kit. (IMG:style_emoticons/default/smilie_pokal.gif)
VaccaRabite
post Jul 15 2019, 06:19 AM
En Garde!
I have a Rennshift and one of Chris's kits in my car. I really like that combo.
It was touchy to get adjusted properly, but the car shifts way easier now. Night and day different.
Zach
Luke M
post Jul 16 2019, 06:32 AM
QUOTE(VaccaRabite @ Jul 15 2019, 05:19 AM) *
Zach
Hi Zach,
I came across this thread just in time. I'm working on putting together some parts for my side shift conv. on my factory 914-6.
I have a new Rennshifter for my factory 914-6 and now looking at getting the rest of the side shift linkage. I'm looking at the Tangerine Racing shift rod kit which comes with the trans shift housing dual bushing mod and the precision shift adjuster.
Would you happen to have any pics of the trans shift housing mod done ?
Any issues installing/adjusting it ?
VaccaRabite
post Jul 16 2019, 08:16 AM
En Garde!
QUOTE(Luke M @ Jul 16 2019, 08:32 AM) *
You will be modifying the shift console on the transmission, which is a lot easier to do with the transmission out of the car.
The smart way to do this is to drain the transmission, but I just dammed up the top vents and nothing leaked out.
Once the spherical bushing is in, grease the hell out of it. it is TIGHT against the shifter bar - which it needs to be. Grease will help. I've either gotten used to it, or its broken in a little.
The splined bar going into the console lever was a PITA to get in and indexed properly. Everything has tighter tolerances now.
When I adjusted the shifter, I needed to clearance something (I can't recall what at the moment) where there was an impingement making it difficult going into the 4/5 plane. I know the shift rod was making contact with something, I just can't remember where. I do recall it being easy to remedy once I found it. After I found that, the shifter adjusted easily. For shifter adjustments I used DrEvils notes.
Chris provides templates for making all your cuts and holes that need drilling.
I've got pics of just about everything I've done to this car over the past 15 (holy shit - 15?!) years... Its just a question of finding them. I can find the bearing install but will have to search for (or more likely just reshoot) a pic of the console mod.
(IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-1435-1563286560.1.jpg)
Spherical bearing installed.
if you are on the fence about this product and you have a Rennshifter- don't be. Buy it. I'm glad I did.
One final word - Mike referred to me as a "horrible person" for lopping off the ear of my perfectly fine shifter console. Maybe ask him for a console with a busted ear already before making the mod. But if you don't be sure to take pictures and tag him in them so you get your dose of the Shreck as well. (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer3.gif)
Zach
post Jul 16 2019, 08:18 AM
914-6 GT in waiting
QUOTE(VaccaRabite @ Jul 16 2019, 10:16 AM) *
Zach
When I adjusted the shifter, I needed to clearance something (I can't recall what at the moment) where there was an impingement making it difficult going into the 4/5 plane. I know the shift rod was making contact with something, I just can't remember where. I do recall it being easy to remedy once I found it. After I found that, the shifter adjusted easily. For shifter adjustments I used DrEvils notes."
Probably the seatbelt bolt.
@VaccaRabite
Luke M
post Jul 16 2019, 08:44 AM
QUOTE(mepstein @ Jul 16 2019, 07:18 AM) *
Zach
@VaccaRabite
Thanks for the info Zach.. When you locate those pics please post them.
I already have the firewall bushing here so one less thing to get.
That's the first thing that came to me as well. I've had that issue in my 71 which drove me nuts. I had put the wrong length bolt in and it was hitting the shift rod.
I have a spare trans console that the bushing ear is snapped off of. I plan to use that one to modify and install. I better get my shopping list going then.
Geezer914   Chris Foley's Tangerine Racing shift linkage kit   Jun 28 2012, 08:46 AM
76-914   :ttiwwp:   Jun 28 2012, 09:01 AM
RobW   :ttiwwp: :agree: but I'm pretty sure its m...   Jun 28 2012, 06:41 PM
Racer Chris   ... I'm pretty sure its mostly a long straigh...   Jun 28 2012, 08:19 PM
JWest   FWIW my Rennshaft linkage popped off at the last ...   Jun 28 2012, 10:02 PM
moggy   I see no advantage over the Rennshift kit with tha...   Jun 28 2012, 12:23 PM
914340   I see no advantage over the Rennshift kit with th...   Jun 28 2012, 12:54 PM
dadaDaveed   I see no advantage over the Rennshift kit with th...   Jun 28 2012, 01:03 PM
JRust   I see no advantage over the Rennshift kit with t...   Jun 28 2012, 01:57 PM
seanery   The shifter and the linkage kit are apples and ora...   Jun 28 2012, 06:01 PM
jim_hoyland   After 7 years, how's it working ? Any sugges...   Jul 14 2019, 08:22 PM
mepstein   Shifting in a 914 is a system, only as good as it...   Jul 14 2019, 09:25 PM
Larmo63   Ask Keith, @914Toy He has done both of thes...   Jul 14 2019, 10:38 PM
914Toy   Ask Keith, [b]@[url=http://www.914world.com/bbs2...   Jul 15 2019, 09:06 AM
VaccaRabite   I have a Rennshift and one of Chris's kits in ...   Jul 15 2019, 06:19 AM
jim_hoyland   I have a Rennshift and one of Chris's kits in...   Jul 15 2019, 06:22 AM
Luke M   I have a Rennshift and one of Chris's kits in...   Jul 16 2019, 06:32 AM
VaccaRabite   [quote name='VaccaRabite' post='2730109' date='Ju...   Jul 16 2019, 08:16 AM
mepstein   [quote name='VaccaRabite' post='2730109' date='J...   Jul 16 2019, 08:18 AM
Luke M   [quote name='VaccaRabite' post='2730357' date='Ju...   Jul 16 2019, 08:44 AM
Olympic 914   I've had that issue in my 71 which drove me...   Jul 17 2019, 07:58 AM
VaccaRabite   When I adjusted the shifter, I needed to clearan...   Jul 16 2019, 04:05 PM
Porschef   http://www.914world.com/bbs2/uploads_offsite/fbc...   Jul 16 2019, 06:02 PM
gereed75   I have a Weltmiester short shift shifter. It simpl...   Jul 15 2019, 06:25 AM
mepstein   On my 3.2 conversion, I have a jwest shifter, full...   Jul 15 2019, 06:32 AM
Cairo94507   Hi Mark- That is the exact set-up I have for my ca...   Jul 15 2019, 06:38 AM
mepstein   I almost forgot - Zach's handmade shift knob. ...   Jul 15 2019, 06:51 AM
Eric_Shea   Jim, We put them on everything. The spherical fir...   Jul 16 2019, 02:50 PM
jim_hoyland   Trigger pulled...: Just submitted an order along w...   Jul 16 2019, 03:01 PM
StratPlayer   You won't be sorry jim,, I've had one on m...   Jul 16 2019, 03:22 PM
jim_hoyland   You won't be sorry jim,, I've had one on ...   Jul 16 2019, 04:07 PM
maf914   Zach, What did you use to cut off the console ear...   Jul 17 2019, 07:33 AM
VaccaRabite   What did you use to cut off the console ear? A c...   Jul 17 2019, 09:33 AM
frank_c   Also, do you use the rear console black plastic b...   May 18 2026, 09:29 PM
brant   shift console mods are great they made another no...   Jul 17 2019, 10:05 AM
brant   the cup bushing extension is in the picture also   Jul 17 2019, 10:05 AM
mepstein   the cup bushing extension is in the picture also ...   Jul 17 2019, 10:30 AM
brant   the cup bushing extension is in the picture also...   Jul 17 2019, 10:33 AM
ChrisFoley   at full extension a part of the plastic bushing ...   Jul 17 2019, 10:38 AM
mepstein   at full extension a part of the plastic bushing...   Jul 17 2019, 11:25 AM
ChrisFoley   Actually, Brant's picture is of a sideshift pi...   Jul 17 2019, 11:42 AM
mepstein   Sideshift or tail?   Jul 17 2019, 12:08 PM
ChrisFoley   Sideshift   Jul 17 2019, 12:31 PM
mepstein   Sideshift Cool. Thanks!   Jul 17 2019, 12:39 PM
3 User(s) are reading this topic (2 Guests and 0 Anonymous Users)
1 Members: troth
- Lo-Fi Version Time is now: 19th May 2026 - 12:58 AM
