Case to Cylinder Sealing Ring, For 102 mm Cylinders |
Mblizzard |
Jul 22 2019, 02:26 PM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
VaccaRabite |
Jul 23 2019, 07:17 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Those spacers are how you set you deck height and static CR. They are not sealing rings. You do 100% need them.
Zach |
Mblizzard |
Jul 23 2019, 07:22 AM
VaccaRabite |
Jul 23 2019, 08:04 AM
Those spacers are how you set you deck height and static CR. They are not sealing rings. You do 100% need them. Zach Zach - Correct will be using them to set compression. Working with Len to cut the heads as well but just need to source the shims. Len does not have them? I would think that he would stock these for the Type4 Store. If he does not have them, European Motor Works would have them. Zach |
Lo-Fi Version | Time is now: 1st June 2024 - 04:10 AM |
