| Garland |
Apr 9 2005, 10:20 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,438 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Well can you see it?
| Garland |
Jul 23 2019, 09:42 PM
Are used a router bit, in a drill press. It’s an old craftsman so I adjusted the belt to a slower speed and used a piece of wood for a fence clamped to the table on one side. Tried two wood guides to slide the piece in but binding became a concern.
I used my first attempt, only because of how much time it took to slowly remove material. I adjusted the depth with each pass. Did about a third at a time, easier to work with that way . |
Garland 3rd Brake Lamp, my best try... Apr 9 2005, 10:20 PM
Garland Ask, and you will see more! Apr 9 2005, 10:24 PM
scott thacher http://www.914world.com/bbs2/... Apr 9 2005, 10:25 PM
Aaron Cox pretty cool...
wheer did you put the wires>? Apr 9 2005, 10:27 PM
Garland A little closer look. Apr 9 2005, 10:38 PM
Garland Wires are inside the stock roll bar. Then behind t... Apr 9 2005, 10:40 PM
Garland Cut the hole in the trim to fit the face of the la... Apr 9 2005, 10:44 PM
Garland Light on Apr 9 2005, 10:46 PM
Garland DOT approved lamp, brightest light on the car. Apr 9 2005, 10:48 PM
Garland Top off. Apr 9 2005, 10:50 PM
Garland Again flush, almost with trim. Did not want to hav... Apr 9 2005, 10:53 PM
Garland This picture just was cool. Apr 9 2005, 10:54 PM
SGB Most certainly a keeper! It is great. Where... Apr 9 2005, 10:57 PM
Flat VW Will that illuminate on deceleration as well as wi... Apr 9 2005, 10:58 PM
Andyrew Who
What
When
Where
How much?
Are you reproductin... Apr 9 2005, 11:04 PM
Garland Apr 9 2005, 11:10 PM
Andyrew I dono.. that car looks expensive.....
what is i... Apr 9 2005, 11:14 PM
Garland You can just see it at the top of the rear glass. ... Apr 9 2005, 11:14 PM
Garland Ford GT Apr 9 2005, 11:16 PM
Andyrew How the heck did you get that part???
How much??
... Apr 9 2005, 11:18 PM
Garland <... Apr 9 2005, 11:22 PM
lagunero Apr 9 2005, 11:23 PM
Aaron Cox that is AWESOME Apr 9 2005, 11:24 PM
Garland Apr 10 2005, 12:38 AM
neo914-6 Demick did similar some time ago for not much less... Apr 10 2005, 01:10 AM
Garland Wow I did the same lamp last year. I wanted someth... Apr 10 2005, 08:11 AM
Elliot Cannon So I can just walk into any Ford dealer and order ... Apr 10 2005, 09:03 AM
Garland ht... Apr 10 2005, 10:40 AM
Jeroen wow! excellent job! Apr 10 2005, 10:45 AM
GeorgeRud Got the part from my local Ford Dealer today. The... Aug 19 2005, 02:44 PM
Ferg wow, that looks great, and I happen to have a spar... Aug 19 2005, 02:54 PM
redshift http://www.914world.com/bbs2/html/e... Aug 19 2005, 03:02 PM
Garland Duplicate post Aug 20 2005, 09:10 PM
Garland Duplicate post Aug 21 2005, 10:37 PM
Garland Duplicate post Aug 21 2005, 10:38 PM
Garland Duplicate post Aug 21 2005, 10:40 PM
Garland The trim needs to be cut out of the top 2/3 for th... Aug 21 2005, 10:41 PM
Garland This shot shows the trim bar upside down. Notice t... Aug 21 2005, 10:42 PM
Garland This is from the back side of the trim. The black ... Aug 21 2005, 10:43 PM
Garland Another view of the backside. Aug 21 2005, 10:43 PM
Garland The wiring comes out the back of the lamp through ... Aug 21 2005, 10:44 PM
Garland Down the sail behind the sail trim, Aug 21 2005, 10:44 PM
Garland and between the left grill end piece, Aug 21 2005, 10:45 PM
Garland into the trunk. Along the left side wiring harness... Aug 21 2005, 10:46 PM
Garland I hope that will help anyone doing this 3rd brake ... Aug 21 2005, 10:47 PM
SpecialK NICELY DONE!! Looks like it should have b... Aug 22 2005, 08:33 PM
Garland A few more shots. Aug 22 2005, 09:18 PM
Garland Parking lamps are on also. Aug 22 2005, 09:22 PM
lotus_65 could a guy feed the wiring into the interior bols... Aug 28 2005, 09:24 AM
Harpo I agree that this is the best looking high mounted... Oct 4 2013, 04:05 PM
StratPlayer That's where I located mine Oct 4 2013, 07:09 PM
Harpo Thanks for the heads up. I just bought one off EB... Oct 5 2013, 07:14 AM
Garland I’ve been wanting to extend the third brake lamp... Jul 23 2019, 05:59 PM
Garland More, and it’s very bright.
Jul 23 2019, 06:03 PM
Tdskip Very neat installation, well done. Jul 23 2019, 08:27 PM
euro911 I have a spare crossbar trim piece and plan to do ... Jul 23 2019, 08:59 PM
euro911 That sounds like a good method. Thanks :thumbsup: Jul 23 2019, 11:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 3rd November 2026 - 04:49 PM |
