Frunk Extremely Hard To Open |
Minerva's 914 |
Jul 24 2019, 03:38 PM
Member Group: Members Posts: 378 Joined: 24-December 15 From: Chapel Hill, NC Member No.: 19,489 Region Association: South East States |
The front trunk is almost impossible to open unless someone presses down on the lid as the cable is pulled. Is there a simple procedure for adjusting the tension on the release latch?
At first I thought maybe it was a pinched or restricted cable but it seems to pull fairly freely with the lid open. HELP |
mepstein |
Jul 24 2019, 06:08 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You need to lube the pull mechanism and the cable. Pull the wire cable out from the housing and lube the wire with a good bicycle lube. It will make all the difference and pulling a difficult cable will eventually cause something to break or pull from the cable stop. For the engine lid, you can just drip some lube from the latch and let gravity do the work.
I like using a dry bike lube (goes on wet but the carrier dries after a bit) on all the pivots and cables. It will distribute to all the moving points but not collect dirt like a wet lube or grease. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:15 PM |
