SOLD: 5 Lug Converted Hubs and Rotors (late style) |
carl k |
Jun 6 2019, 08:55 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
SOLD!
Here's a complete set of drilled, studded 5 lug hubs and rotors for a 914. The fronts are the later type with the hub centering ring. Front rotors have screw in studs and are cast with a "411" part number, so perhaps they were OEM. Rear hubs have 65mm long, press in studs with backup TIG welds. Rotors have little to no wear, are smooth. Fronts measure .428" thick, rears are .369" (both within the tolerances of new rotors). I don't think the car from which these came was really driven after being converted. SOLD thanks! Carl |
bdstone914 |
Jun 7 2019, 07:45 AM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Good deal for the right person.
The buyer should know that the 65mm studs in the rear hubs require 21mm spacers. That partially threaded stud style stud does allow a lug nut to tighten down with out a spacer. Not easily swapped as they are welded in. Good luck with sale. Bruce |
carl k |
Jun 7 2019, 07:52 AM
Bruce-
Yes, these were used with spacers on a flared car. Thanks for pointing that out. Carl |
carl k |
Jun 12 2019, 12:35 PM
Bump- possible free delivery to Sacramento/Truckee regions this weekend.
-Carl |
carl k |
Jul 26 2019, 06:25 PM
can ship in three large Flat Rate boxes anywhere in the continental USA for $65.
-Carl |
Lo-Fi Version | Time is now: 11th June 2024 - 08:00 AM |
