> fiberglass question(s), 914 related, trust me :)
Mueller
post Dec 1 2004, 06:05 PM
914 Freak!
trying to find the max temperature the fiber can withstand....
I'm also trying to find a high heat tolerant resin (once everything is dried and cured)
once cured and exposed to an enviorment that is in the 200°-300°+ range, would I have to worry about dangerous outgassing??
SpecialK
post Dec 1 2004, 06:44 PM
aircraft surgeon
Most epoxy resin's have a cure range of around 200F. After heat curing, the composite can with stand substantially higher temps (probably 400F max.). The fiberglass cloth should be okay to near 1000F (well beyond what the resin can withstand). Is there any way that you could apply a heat reflective coating to the side of your project that'll be exposed to the high temps? I'm toying with making a set of CF engine tins using an aluminum impregnated FG (heat reflective) layer on the inside, hell, I might make the entire engine tin out of the AI FG if my practice pieces look cool.
Here's a pic of the Impregnated FG:
- Lo-Fi Version Time is now: 2nd April 2026 - 11:11 AM
