> 914 613 541 02A back up switch connection, need the "bullet type" connector end
Str1974
post May 12 2019, 07:07 PM
I have a question regarding the back-up switch. I needed to replace it because the wiring connectors had broken off right where they plug into the two female connections on the switch (one underneath the back drivers side section of engine). I would have spliced the wire and connectors if I would have any length of wire left. All I have is bare wire and the two female connections. I've been trying to locate the right size bullet connectors that could be hooked up to bare wire, but no luck. The back up switch is easy to locate and purchase, but I cannot locate the male connectors. Any advise?
JeffBowlsby
post Jul 31 2019, 09:32 PM
4.5mm is the correct size for these terminals.
- Lo-Fi Version Time is now: 2nd April 2026 - 10:02 AM
