| markb |
May 20 2003, 05:53 PM
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,450 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California
Hi All! I'm in dire need of a replacement bushing for my left rear control arm. I can't seem to find a replacement part number. Can anybody point me in the right direction? (IMG:style_emoticons/default/unsure.gif)
| Mueller |
May 21 2003, 02:54 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Hey Mark,
Sorry to take so long to get back to you....swamped right now, in fact I was working until 3:30 AM to finish a rear kit to send back East today. (he is running the Shine kit on front) Mine; Fronts: 400 Rears: 400 Thiers; Fronts: 485 Rears: 485 Discounts for multiple purchases (more than one car) rdauenhauer, Use in the wet should not be a problem if good quailty grease is used, in fact boat trailer wheel bearing grease would be ideal. The rears have an o-ring. The fronts use an o-ring and RTV for sealing, a zerk fitting could be installed, but it would require match drilling after assembly, not that hard, but I could draw it up to make it owner optional. As long as one does not directly steam wash or pressure wash the suspension points, the grease is not going to go anywhere. Mike |
markb Rear Control Arm Bushings May 20 2003, 05:53 PM
Brad Roberts You wont find one.
You have to convert the car ov... May 20 2003, 06:08 PM
markb Does that mean Mike M's fancy new bearings wor... May 20 2003, 07:18 PM
Brad Roberts He has a rear bearing kit. I just did ANOTHER inst... May 20 2003, 07:20 PM
morgan :question: how much does that ruun for front and b... May 21 2003, 06:39 AM
rdauenhauer Brad, Mike, I am very intrigued with using the rol... May 21 2003, 12:52 PM
Qarl I'm going roller too! Sent my check off t... May 21 2003, 01:00 PM
maf914 In the Grassroots Motorsport magazine 914 Project ... May 21 2003, 01:47 PM
URY914 They used units from Shine Racing in Mass.
Mike m... May 21 2003, 01:52 PM
seanery Mike offers both front & rear.
I've seen them... May 21 2003, 02:18 PM
Brad Roberts I pulled them apart to check them (street car afte... May 21 2003, 07:10 PM
markb Brad, you're making this way too hard to resis... May 21 2003, 10:45 PM
Brad Roberts Mikey... here you go:
I assembled "another" arm f... May 22 2003, 12:36 AM
Brad Roberts ergwe May 22 2003, 12:36 AM
Brad Roberts qert May 22 2003, 12:37 AM
Mueller Hey Mark,
Does the 'Capt'n know?
I... May 22 2003, 10:37 AM
Brad Roberts Yep...and we should all take our braided brake lin... May 22 2003, 11:03 AM
markb To be honest, Mike, the Cap'n had never seen o... May 22 2003, 04:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th March 2026 - 02:12 AM |
