Something Evil Part II, Starting Over |
Mblizzard |
Apr 17 2019, 08:17 AM
Advanced Member Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Well I have been delayed with life and too many things going on. But after purchasing a lot of parts, it is time to start the process.
Up front big thanks to Charles and Nicole at the Type 4 Store for putting up with so many questions. Thanks to Len Hoffman for waiting on me for so long on the heads. Also to Jake Raby for his Type 4 build CD and while not giving build advice but pointing me in the right direction on a number of issues. I am afraid to look at all of the other vendor receipts as I might start to add it all up $$$$ but I will compile a list of all the vendors and add photos. So the basics. Going for a 2.6 L FI with Microsquirt. Looking to hit 9.5:1 compression. 102 mm Nickies with Custom 102mm Dished JE Pistons for 78mm stroke and 22mm pins. 78 mm crank - New this time! H-beam Rods 5.325 with Type 1 Rod Journals LE-200 heads - Valve sizes: 44mm x 38mm by Manley, intake ports flow 200CFM @ .500” valve lift, and ceramic coated. 911 swivel foot valve adjusters SPEC Clutch Kit - Stage 1 Lightened flywheel Type 4 Store Cam Part# 9500 with Parkerized Lifters and Modified Cam Gear, chromoly pushrods Intake Valve Lift: .500 Duration: 284 Duration@ .050": 250 Exhaust Valve Lift: .500 Duration: 300 Duration@ .050": 270 Mahle bearings throughout 315cc/min Fuel Injector: Bosch 0280150945 48 mm CB Performance intakes. Dual throttle bodies with CSP linkage Modified 30mm Oil Pump Racewear Case thru-Stud Kit and Head Stud Kit Tangerine Racing Remote Oil Cooler Kit Planning on Tangerine Racing 1 1/2" Street System: - High Temp coated header with EVO II Silencer Case and all the parts are going to shop Friday for opening up to fit the 102s and balancing of all parts. Goal is to be done by Okteenerfest! May have potential to be evil? Thoughts suggestions? |
Mblizzard |
Aug 1 2019, 06:58 AM
Well not a lot of progress as of late. Still sorting out the rod issue but Charles at the Type 4 Store has been great in working with me on the issue!
Really have to thank Len Hoffman. He is fast tracking my heads at the ceramic coater so I can get them by Aug 9. (IMG:style_emoticons/default/pray.gif) Cant wait to see the LE-200 heads with the coating done. Combined with the Tangerine Racing 1-3/4 headers and Evo Muffler it ought to breath well! He is setting them up with a 1mm step so with zero deck height in the jugs I will be at 9.99:1 compression. Everyone likely says NO on the deck zero height but the pistons have valve cut outs that should allow for clearance. I will check of course! As long as the pistons are not sticking out of the jugs I should not need any cylinder shims. If needed, I can add as much as .5mm (0.02 in) deck height and only reduce the compression to 9.5:1. I have ordered those shims just in case! |
Betty |
Aug 1 2019, 11:39 AM
Driver Group: Members Posts: 511 Joined: 10-December 04 From: Hurst, TX Member No.: 3,255 Region Association: South East States |
Well not a lot of progress as of late. Still sorting out the rod issue but Charles at the Type 4 Store has been great in working with me on the issue! Really have to thank Len Hoffman. He is fast tracking my heads at the ceramic coater so I can get them by Aug 9. (IMG:style_emoticons/default/pray.gif) Cant wait to see the LE-200 heads with the coating done. Combined with the Tangerine Racing 1-3/4 headers and Evo Muffler it ought to breath well! He is setting them up with a 1mm step so with zero deck height in the jugs I will be at 9.99:1 compression. Everyone likely says NO on the deck zero height but the pistons have valve cut outs that should allow for clearance. I will check of course! As long as the pistons are not sticking out of the jugs I should not need any cylinder shims. If needed, I can add as much as .5mm (0.02 in) deck height and only reduce the compression to 9.5:1. I have ordered those shims just in case! (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/type.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/beer3.gif) |
Lo-Fi Version | Time is now: 1st June 2024 - 10:51 AM |
