| Mueller |
Dec 1 2004, 06:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
trying to find the max temperature the fiber can withstand....
I'm also trying to find a high heat tolerant resin (once everything is dried and cured) once cured and exposed to an enviorment that is in the 200°-300°+ range, would I have to worry about dangerous outgassing?? |
| redshift |
Dec 1 2004, 08:41 PM
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
If you make your whole tube car out of tubes.. and carbon, you can afford that extra angus burger, once a month.
Mmmmm beef.. (IMG:style_emoticons/default/smile.gif) M |
Mueller fiberglass question(s) Dec 1 2004, 06:05 PM
rick 918-S I'm researching resins myself. I have a cool 9... Dec 1 2004, 06:30 PM
SpecialK Most epoxy resin's have a cure range of around... Dec 1 2004, 06:44 PM
URY914 Jake uses a "tooling resin" which has a higher tem... Dec 1 2004, 07:59 PM
neo914-6 I used to work with a UK vendor who made phenolic ... Dec 1 2004, 08:10 PM
SpecialK Uh oh Paul, giving away Jakes secret recipes ;)
... Dec 1 2004, 08:12 PM
Aaron Cox c/f engine tin!!! :D Dec 1 2004, 08:26 PM
URY914 I've thought of making my tin or the fan housi... Dec 1 2004, 08:29 PM
SpecialK ... Dec 1 2004, 08:31 PM
redshift
URY914
URY914 I told my wife not to throw away those cardboard t... Dec 1 2004, 08:51 PM
Howard R Try these dudes:
http://www.westsystem.com/ Dec 1 2004, 09:11 PM
Dr Evil try these guys too.
http://www.diversifiedmateria... Dec 1 2004, 09:13 PM
jonwatts These guys might know a thing or two about high-he... Dec 1 2004, 10:59 PM
jkeyzer What does "heat resistance" (in degrees F) mean wh... Dec 1 2004, 11:03 PM
rick 918-S <... Dec 1 2004, 11:29 PM
Jake Raby A full set of Carbon Fiber engine tin is already b... Dec 2 2004, 12:04 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:12 AM |
