Help please! alignment specs ? |
PatrickB |
Aug 2 2019, 06:52 AM
Member Group: Members Posts: 249 Joined: 26-March 17 From: sw ontario Member No.: 20,960 Region Association: Canada |
At a shop to check alignment after some work. They don't have a spec for 914's . They do have 911 specs.... anyone know if they are the same ? I wouldn't think so but....
Can anyone point |
Gatornapper |
Aug 2 2019, 07:04 AM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
At a shop to check alignment after some work. They don't have a spec for 914's . They do have 911 specs.... anyone know if they are the same ? I wouldn't think so but.... Can anyone point From 1976 Owner's Manual: Camber - Front: 0 deg. +/- 20' Rear: 30 deg. +/- 20' Toe-in: Front: +20' +/- 10' Rear: 0 deg. +15' (w/33 lbs. curb weight added) Caster angle (at curb weight): 6 deg. +/- 30' GN |
dr914@autoatlanta.com |
Aug 2 2019, 09:12 AM
914 Guru Group: Members Posts: 7,896 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
It is 30 MINUTES neg camber in the rear and 0 in the front.
Make sure that you have correct height in the rear so you will not have to stack too many shims to achieve camber. (basically show three inches of tire between the wheel rim and the fender lip At a shop to check alignment after some work. They don't have a spec for 914's . They do have 911 specs.... anyone know if they are the same ? I wouldn't think so but.... Can anyone point From 1976 Owner's Manual: Camber - Front: 0 deg. +/- 20' Rear: 30 deg. +/- 20' Toe-in: Front: +20' +/- 10' Rear: 0 deg. +15' (w/33 lbs. curb weight added) Caster angle (at curb weight): 6 deg. +/- 30' GN |
Lo-Fi Version | Time is now: 9th June 2024 - 08:21 PM |
