> Need Massive Help, Case failure
Mblizzard
post Aug 9 2019, 05:32 PM
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam.
I have a massive amount of money in this case and it is opened for my 102s.
Anyone think of if and where I can get this repaired quickly?
Superhawk996
post Aug 10 2019, 02:54 AM
Slow down. Desperation and trying to do anything quickly at this point will only lead to more problems.
Anything can be fixed with enough time and money.
Question is do you have enough of both?
Old joke is you can have only two of the three.
Quick job
Affordable job
Quality job
If you want affordable repair and a quality repair it won't be quick.
Want a quick repair and don't want to spend money, it won't be quality work.
(In no way am I referring to Ben - he will do quality and will do affordable to help a member I'm sure. But the machine work isn't quick)
Think long and hard about trying to save this case. At a minimum you will need to line bore the cam. After welding the cam I'd closely remeasure the crank bores for deformation. Highly likely you would want to line bore the crank too in addition to the need to line bore the cam.
Line boring cases is not for the faint of heart. I know it is commonly done but honestly it is hard to do it right and maintain proper dimensional relationship between crank and cam bores. Even at the factory they dealt with this by select fitting cam gears to take up any dimensional variation between crank centerline and cam centerline.
Are you ready to consider rechecking the cylinder openings too after welding?
After all that - a new case looks better and better.
I am so sorry that you're in this situation. I can feel the pain and anguish, and I've been there before too!
Mblizzard   Need Massive Help   Aug 9 2019, 05:32 PM
mepstein   Ask Ben if it’s something that he can do. @MB...   Aug 9 2019, 05:47 PM
Chi-town   If you have it welded you're still going to ha...   Aug 9 2019, 06:11 PM
mb911   It looks like aluminum so most any good TIG welder...   Aug 9 2019, 07:32 PM
Mblizzard   It looks like aluminum so most any good TIG welde...   Aug 9 2019, 07:40 PM
thelogo   Ok so some of you may know I am doing the build o...   Aug 9 2019, 10:35 PM
Larmo63   Just do a /6 and get it over with.   Aug 9 2019, 10:42 PM
90quattrocoupe   Sorry to see this. It can be welded up. Maybe a ...   Aug 9 2019, 10:52 PM
Valy   Ok so some of you may know I am doing the build o...   Aug 10 2019, 01:41 AM
Superhawk996   Slow down. Desperation and trying to do anything ...   Aug 10 2019, 02:54 AM
IronHillRestorations   Easiest thing to do is get a new/different case   Aug 10 2019, 05:25 AM
Mark Henry   Easiest thing to do is get a new/different case ...   Aug 10 2019, 05:54 AM
HAM Inc   This is a terrible turn of events for Michael. I k...   Aug 10 2019, 06:45 AM
Cairo94507   OMG! I am sorry to see that. We all know what...   Aug 10 2019, 08:12 AM
76-914   :( My condolences. Still trying to figure out how...   Aug 10 2019, 09:46 AM
Spoke   What a bummer. How did this happen since it you we...   Aug 10 2019, 09:51 AM
ChrisFoley   I would repair it if it was mine. Careful build-up...   Aug 10 2019, 10:45 AM
Porschef   I would repair it if it was mine. Careful build-u...   Aug 10 2019, 01:17 PM
flyer86d   I would repair it if it was mine. Careful build-u...   Aug 10 2019, 04:55 PM
Mblizzard   I would repair it if it was mine. Careful build-u...   Aug 10 2019, 05:52 PM
ChrisFoley   I would repair it if it was mine. Careful build-...   Aug 11 2019, 09:20 AM
Mblizzard   [quote name='Mblizzard' post='2737175' date='Aug ...   Aug 11 2019, 06:42 PM
dr914@autoatlanta.com   yes it can be welded and align bored, c&j weld...   Aug 10 2019, 11:00 AM
Superhawk996   :popcorn: I see the back and forth on this thread...   Aug 10 2019, 02:02 PM
Bills914-4   Damn, so sorry Mike , you have alot of work in th...   Aug 10 2019, 04:09 PM
Rand   Sometimes we expect too much of an old thing. Plea...   Aug 10 2019, 04:58 PM
Mblizzard   All good advice. But I think I am going to see if ...   Aug 10 2019, 05:51 PM
mepstein   Mike - I know you really really want to get your e...   Aug 10 2019, 06:48 PM
rhodyguy   :agree: a replacement case is the least expensive ...   Aug 10 2019, 08:45 PM
porschetub   Now that is sh#t luck after all you have been thro...   Aug 11 2019, 12:36 AM
Mblizzard   Any suggestions on who could bore out the case to ...   Aug 11 2019, 08:17 AM
Mark Henry   You don't need to timesert the case headstuds ...   Aug 11 2019, 08:41 AM
bdstone914   @mblizzard Mike, I would contact George at Europ...   Aug 11 2019, 09:32 AM
Larmo63   I second the Jorge recommendation if you need it q...   Aug 11 2019, 10:45 PM
Mblizzard   Ok so now I am trying to find someone that can ope...   Aug 12 2019, 08:28 AM
Betty   Ok so now I am trying to find someone that can op...   Aug 12 2019, 09:12 PM
Jetsetsurfshop   Ok so now I am trying to find someone that can op...   Aug 13 2019, 08:02 AM
Mblizzard   Ok so now I am trying to find someone that can o...   Aug 13 2019, 08:04 AM
Jetsetsurfshop   [quote name='Jetsetsurfshop' post='2737953' date=...   Aug 13 2019, 08:24 AM
Mblizzard   [quote name='Jetsetsurfshop' post='2737953' date...   Aug 13 2019, 09:35 AM
Mblizzard   Ok so it just won’t end! Shop called today a...   Aug 13 2019, 05:18 PM
mepstein   Mike - I have a good case that I can send you (or ...   Aug 13 2019, 05:43 PM
Mblizzard   Mike - I have a good case that I can send you (or...   Aug 13 2019, 07:05 PM
mb911   Mike all I can say is wow.. I hope you have no mor...   Aug 14 2019, 04:33 AM
Mblizzard   Well I have to give Jorge at European Motor Works ...   Aug 14 2019, 01:25 PM
thelogo   Well I have to give Jorge at European Motor Works...   Aug 14 2019, 05:36 PM
theer   Great news! Congrats. Mike - I have a good ...   Aug 14 2019, 01:35 PM
914dave   Mike. Sorry to see your troubles. Seems like the ...   Aug 14 2019, 04:30 PM
Mblizzard   Mike. Sorry to see your troubles. Seems like the...   Aug 14 2019, 07:25 PM
db9146   Mike, any update? I hope you are too busy making ...   Aug 23 2019, 08:18 PM
Mblizzard   Mike, any update? I hope you are too busy making...   Aug 24 2019, 09:29 AM
- Lo-Fi Version Time is now: 4th June 2026 - 01:17 AM
