> Need Massive Help, Case failure
Mblizzard
post Aug 9 2019, 05:32 PM
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam.
I have a massive amount of money in this case and it is opened for my 102s.
Anyone think of if and where I can get this repaired quickly?
ChrisFoley
post Aug 10 2019, 10:45 AM
I am Tangerine Racing
I would repair it if it was mine.
Careful build-up with TIG, no use trying to weld the broken bit back on. Then hand grind/file/scrape until a custom made gauge pin barely fit through the bore - always being careful to not cut into the remaining original bore surface nearby.
I wouldn't use a reamer - too much chance of removing material from the other case half.
1 hour for the weld process and another 3-4 hours of hand work.
Tedious, but doable and worth it to recover the investment.
Porschef
post Aug 10 2019, 01:17 PM
How you doin'
QUOTE(ChrisFoley @ Aug 10 2019, 12:45 PM) *
Wow
(IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
Sorry to see this, you must be heartbroken. (IMG:style_emoticons/default/sad.gif)
Mblizzard   Need Massive Help   Aug 9 2019, 05:32 PM
mepstein   Ask Ben if it’s something that he can do. @MB...   Aug 9 2019, 05:47 PM
Chi-town   If you have it welded you're still going to ha...   Aug 9 2019, 06:11 PM
mb911   It looks like aluminum so most any good TIG welder...   Aug 9 2019, 07:32 PM
Mblizzard   It looks like aluminum so most any good TIG welde...   Aug 9 2019, 07:40 PM
thelogo   Ok so some of you may know I am doing the build o...   Aug 9 2019, 10:35 PM
Larmo63   Just do a /6 and get it over with.   Aug 9 2019, 10:42 PM
90quattrocoupe   Sorry to see this. It can be welded up. Maybe a ...   Aug 9 2019, 10:52 PM
Valy   Ok so some of you may know I am doing the build o...   Aug 10 2019, 01:41 AM
Superhawk996   Slow down. Desperation and trying to do anything ...   Aug 10 2019, 02:54 AM
IronHillRestorations   Easiest thing to do is get a new/different case   Aug 10 2019, 05:25 AM
Mark Henry   Easiest thing to do is get a new/different case ...   Aug 10 2019, 05:54 AM
HAM Inc   This is a terrible turn of events for Michael. I k...   Aug 10 2019, 06:45 AM
Cairo94507   OMG! I am sorry to see that. We all know what...   Aug 10 2019, 08:12 AM
76-914   :( My condolences. Still trying to figure out how...   Aug 10 2019, 09:46 AM
Spoke   What a bummer. How did this happen since it you we...   Aug 10 2019, 09:51 AM
ChrisFoley   I would repair it if it was mine. Careful build-up...   Aug 10 2019, 10:45 AM
Porschef   I would repair it if it was mine. Careful build-u...   Aug 10 2019, 01:17 PM
flyer86d   I would repair it if it was mine. Careful build-u...   Aug 10 2019, 04:55 PM
Mblizzard   I would repair it if it was mine. Careful build-u...   Aug 10 2019, 05:52 PM
ChrisFoley   I would repair it if it was mine. Careful build-...   Aug 11 2019, 09:20 AM
Mblizzard   [quote name='Mblizzard' post='2737175' date='Aug ...   Aug 11 2019, 06:42 PM
dr914@autoatlanta.com   yes it can be welded and align bored, c&j weld...   Aug 10 2019, 11:00 AM
Superhawk996   :popcorn: I see the back and forth on this thread...   Aug 10 2019, 02:02 PM
Bills914-4   Damn, so sorry Mike , you have alot of work in th...   Aug 10 2019, 04:09 PM
Rand   Sometimes we expect too much of an old thing. Plea...   Aug 10 2019, 04:58 PM
Mblizzard   All good advice. But I think I am going to see if ...   Aug 10 2019, 05:51 PM
mepstein   Mike - I know you really really want to get your e...   Aug 10 2019, 06:48 PM
rhodyguy   :agree: a replacement case is the least expensive ...   Aug 10 2019, 08:45 PM
porschetub   Now that is sh#t luck after all you have been thro...   Aug 11 2019, 12:36 AM
Mblizzard   Any suggestions on who could bore out the case to ...   Aug 11 2019, 08:17 AM
Mark Henry   You don't need to timesert the case headstuds ...   Aug 11 2019, 08:41 AM
bdstone914   @mblizzard Mike, I would contact George at Europ...   Aug 11 2019, 09:32 AM
Larmo63   I second the Jorge recommendation if you need it q...   Aug 11 2019, 10:45 PM
Mblizzard   Ok so now I am trying to find someone that can ope...   Aug 12 2019, 08:28 AM
Betty   Ok so now I am trying to find someone that can op...   Aug 12 2019, 09:12 PM
Jetsetsurfshop   Ok so now I am trying to find someone that can op...   Aug 13 2019, 08:02 AM
Mblizzard   Ok so now I am trying to find someone that can o...   Aug 13 2019, 08:04 AM
Jetsetsurfshop   [quote name='Jetsetsurfshop' post='2737953' date=...   Aug 13 2019, 08:24 AM
Mblizzard   [quote name='Jetsetsurfshop' post='2737953' date...   Aug 13 2019, 09:35 AM
Mblizzard   Ok so it just won’t end! Shop called today a...   Aug 13 2019, 05:18 PM
mepstein   Mike - I have a good case that I can send you (or ...   Aug 13 2019, 05:43 PM
Mblizzard   Mike - I have a good case that I can send you (or...   Aug 13 2019, 07:05 PM
mb911   Mike all I can say is wow.. I hope you have no mor...   Aug 14 2019, 04:33 AM
Mblizzard   Well I have to give Jorge at European Motor Works ...   Aug 14 2019, 01:25 PM
thelogo   Well I have to give Jorge at European Motor Works...   Aug 14 2019, 05:36 PM
theer   Great news! Congrats. Mike - I have a good ...   Aug 14 2019, 01:35 PM
914dave   Mike. Sorry to see your troubles. Seems like the ...   Aug 14 2019, 04:30 PM
Mblizzard   Mike. Sorry to see your troubles. Seems like the...   Aug 14 2019, 07:25 PM
db9146   Mike, any update? I hope you are too busy making ...   Aug 23 2019, 08:18 PM
Mblizzard   Mike, any update? I hope you are too busy making...   Aug 24 2019, 09:29 AM
- Lo-Fi Version Time is now: 4th June 2026 - 01:18 AM
