| Mblizzard |
Aug 9 2019, 05:32 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States |
Ok so some of you may know I am doing the build of my life.
Put the case together for checking fit all went fine everything turned great. Disassembled and found this break in the case at the cam. I have a massive amount of money in this case and it is opened for my 102s. Anyone think of if and where I can get this repaired quickly? |
| Bills914-4 |
Aug 10 2019, 04:09 PM
Member ![]() ![]() Group: Members Posts: 313 Joined: 1-March 08 From: suburbs of Miami FL. Member No.: 8,762 Region Association: South East States |
Damn, so sorry Mike , you have alot of work in that case , timeserts, bore for 102's,
shuffle pins, ect, , I might try and save it , I would put a correct dia. (cam bearing o.d.) bar in the cam bore , v-out the crack inside ,pull the piece back against the bar with small clamp gently , Weld the outside crack let it cool ,remove clamp & bar , then weld the v-grooved crack , once it's cooled dremel down the weld , check it by sliding the Bar back towards the welded cam saddle seeing if the bar stops , using it as a gage , clearance it until it slides in smoothly , then assemble the case with cam+bearings only , torque it down little by little checking for cam binding by tuning the cam , then mill file the parting surface to match , just another idea Bill D. ps you can hold the bar in the cam saddles with a couple of straps going thru the cylinder bores and around a wood 2x2 , |
Mblizzard Need Massive Help Aug 9 2019, 05:32 PM
mepstein Ask Ben if it’s something that he can do.
@MB... Aug 9 2019, 05:47 PM
Chi-town If you have it welded you're still going to ha... Aug 9 2019, 06:11 PM
mb911 It looks like aluminum so most any good TIG welder... Aug 9 2019, 07:32 PM
Mblizzard
It looks like aluminum so most any good TIG welde... Aug 9 2019, 07:40 PM
thelogo
Ok so some of you may know I am doing the build o... Aug 9 2019, 10:35 PM
Larmo63 Just do a /6 and get it over with. Aug 9 2019, 10:42 PM
90quattrocoupe Sorry to see this.
It can be welded up. Maybe a ... Aug 9 2019, 10:52 PM
Valy
Ok so some of you may know I am doing the build o... Aug 10 2019, 01:41 AM
Superhawk996 Slow down. Desperation and trying to do anything ... Aug 10 2019, 02:54 AM
IronHillRestorations Easiest thing to do is get a new/different case Aug 10 2019, 05:25 AM
Mark Henry
... Aug 10 2019, 05:54 AM
HAM Inc This is a terrible turn of events for Michael. I k... Aug 10 2019, 06:45 AM
Cairo94507 OMG! I am sorry to see that. We all know what... Aug 10 2019, 08:12 AM
76-914 :( My condolences. Still trying to figure out how... Aug 10 2019, 09:46 AM
Spoke What a bummer. How did this happen since it you we... Aug 10 2019, 09:51 AM
ChrisFoley I would repair it if it was mine.
Careful build-up... Aug 10 2019, 10:45 AM
Porschef
Careful build-u... Aug 10 2019, 01:17 PM
flyer86d
Careful build-u... Aug 10 2019, 04:55 PM
Mblizzard
Careful build-u... Aug 10 2019, 05:52 PM
ChrisFoley
Careful build-... Aug 11 2019, 09:20 AM
Mblizzard
[quote name='Mblizzard' post='2737175' date='Aug ... Aug 11 2019, 06:42 PM
dr914@autoatlanta.com yes it can be welded and align bored, c&j weld... Aug 10 2019, 11:00 AM
Superhawk996 :popcorn:
I see the back and forth on this thread... Aug 10 2019, 02:02 PM
Rand Sometimes we expect too much of an old thing. Plea... Aug 10 2019, 04:58 PM
Mblizzard All good advice. But I think I am going to see if ... Aug 10 2019, 05:51 PM
mepstein Mike - I know you really really want to get your e... Aug 10 2019, 06:48 PM
rhodyguy :agree: a replacement case is the least expensive ... Aug 10 2019, 08:45 PM
porschetub Now that is sh#t luck after all you have been thro... Aug 11 2019, 12:36 AM
Mblizzard Any suggestions on who could bore out the case to ... Aug 11 2019, 08:17 AM
Mark Henry You don't need to timesert the case headstuds ... Aug 11 2019, 08:41 AM
bdstone914 @mblizzard
Mike, I would contact George at Europ... Aug 11 2019, 09:32 AM
Larmo63 I second the Jorge recommendation if you need it q... Aug 11 2019, 10:45 PM
Mblizzard Ok so now I am trying to find someone that can ope... Aug 12 2019, 08:28 AM
Betty
Ok so now I am trying to find someone that can op... Aug 12 2019, 09:12 PM
Jetsetsurfshop
Ok so now I am trying to find someone that can op... Aug 13 2019, 08:02 AM
Mblizzard
Ok so now I am trying to find someone that can o... Aug 13 2019, 08:04 AM
Jetsetsurfshop
[quote name='Jetsetsurfshop' post='2737953' date=... Aug 13 2019, 08:24 AM
Mblizzard
[quote name='Jetsetsurfshop' post='2737953' date... Aug 13 2019, 09:35 AM
Mblizzard Ok so it just won’t end! Shop called today a... Aug 13 2019, 05:18 PM
mepstein Mike - I have a good case that I can send you (or ... Aug 13 2019, 05:43 PM
Mblizzard
Mike - I have a good case that I can send you (or... Aug 13 2019, 07:05 PM
mb911 Mike all I can say is wow.. I hope you have no mor... Aug 14 2019, 04:33 AM
Mblizzard Well I have to give Jorge at European Motor Works ... Aug 14 2019, 01:25 PM
thelogo
Well I have to give Jorge at European Motor Works... Aug 14 2019, 05:36 PM
theer Great news! Congrats.
Mike - I have a good ... Aug 14 2019, 01:35 PM
914dave Mike.
Sorry to see your troubles. Seems like the ... Aug 14 2019, 04:30 PM
Mblizzard
Mike.
Sorry to see your troubles. Seems like the... Aug 14 2019, 07:25 PM
db9146 Mike, any update? I hope you are too busy making ... Aug 23 2019, 08:18 PM
Mblizzard
Mike, any update? I hope you are too busy making... Aug 24 2019, 09:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th June 2026 - 01:20 AM |
