Something Evil Part II, Starting Over |
Mblizzard |
Apr 17 2019, 08:17 AM
Well I have been delayed with life and too many things going on. But after purchasing a lot of parts, it is time to start the process.
Up front big thanks to Charles and Nicole at the Type 4 Store for putting up with so many questions. Thanks to Len Hoffman for waiting on me for so long on the heads. Also to Jake Raby for his Type 4 build CD and while not giving build advice but pointing me in the right direction on a number of issues. I am afraid to look at all of the other vendor receipts as I might start to add it all up $$$$ but I will compile a list of all the vendors and add photos. So the basics. Going for a 2.6 L FI with Microsquirt. Looking to hit 9.5:1 compression. 102 mm Nickies with Custom 102mm Dished JE Pistons for 78mm stroke and 22mm pins. 78 mm crank - New this time! H-beam Rods 5.325 with Type 1 Rod Journals LE-200 heads - Valve sizes: 44mm x 38mm by Manley, intake ports flow 200CFM @ .500” valve lift, and ceramic coated. 911 swivel foot valve adjusters SPEC Clutch Kit - Stage 1 Lightened flywheel Type 4 Store Cam Part# 9500 with Parkerized Lifters and Modified Cam Gear, chromoly pushrods Intake Valve Lift: .500 Duration: 284 Duration@ .050": 250 Exhaust Valve Lift: .500 Duration: 300 Duration@ .050": 270 Mahle bearings throughout 315cc/min Fuel Injector: Bosch 0280150945 48 mm CB Performance intakes. Dual throttle bodies with CSP linkage Modified 30mm Oil Pump Racewear Case thru-Stud Kit and Head Stud Kit Tangerine Racing Remote Oil Cooler Kit Planning on Tangerine Racing 1 1/2" Street System: - High Temp coated header with EVO II Silencer Case and all the parts are going to shop Friday for opening up to fit the 102s and balancing of all parts. Goal is to be done by Okteenerfest! May have potential to be evil? Thoughts suggestions? |
914forme |
Aug 13 2019, 07:00 AM
You will always pay when you rush.
My suggestion if you re going to put this engine together in a weekend. Clean up while you are waiting. Get everything you will need laid out on the table(s) all tools, all chemicals, parts everything. White board note pad what ever and build a check list. All tools and supplies applicators etc... must go back to the spot. Count your danm rags. I use paint pens also to mark when bolts and studs have been torqued. Torque, mark, torque mark. Clean tools put them back on the table in the same spot. Count all my rags, sponges, qtips what the not. You are an engine surgeon , you must be precise and know what, where and why. Take the upcoming days to prep well, and you will be ready to get it done. HAVE A FREAKING CHECK LIST AND USE IT! Don't know how many times I have skipped a step and paid hard for it latter. The more I am rushed the worse it gets. I built an engine once, got it fired up, and promptly left the oil fill cap off of it. That almost cost me a nice race engine. I was trying to get to an event the next day. Do not be like this bone head. Learn from my mistakes. All my car guy friends seem to have a similar story. |
Mblizzard |
Aug 13 2019, 07:16 AM
You will always pay when you rush. My suggestion if you re going to put this engine together in a weekend. Clean up while you are waiting. Get everything you will need laid out on the table(s) all tools, all chemicals, parts everything. White board note pad what ever and build a check list. All tools and supplies applicators etc... must go back to the spot. Count your danm rags. I use paint pens also to mark when bolts and studs have been torqued. Torque, mark, torque mark. Clean tools put them back on the table in the same spot. Count all my rags, sponges, qtips what the not. You are an engine surgeon , you must be precise and know what, where and why. Take the upcoming days to prep well, and you will be ready to get it done. HAVE A FREAKING CHECK LIST AND USE IT! Don't know how many times I have skipped a step and paid hard for it latter. The more I am rushed the worse it gets. I built an engine once, got it fired up, and promptly left the oil fill cap off of it. That almost cost me a nice race engine. I was trying to get to an event the next day. Do not be like this bone head. Learn from my mistakes. All my car guy friends seem to have a similar story. So true! But I am going back to the beginning and cleaning everything over again between now and the weekend. On the first go I set myself small incremental goals for each night which seemed to work well. Tonight is pull rods, timing gear, and dizzy off crank. But I think i will write it all out just to be sure! Went back and reordered some parts that I don't like to use over like woodruff keys. I know they are fine to reuse but... Also going to go back through and check all of my clearances and such. That would be a good list to have for stock builds. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:11 PM |
