Grosbard |
Member ![]() ![]() Group: Members Posts: 88 Joined: 29-September 09 From: Pasadena, CA Member No.: 10,862 Region Association: Southern California ![]() ![]() |
Wanted to get some experts to weigh in here. I ordered this part from Auto Atlanta:
http://www.autoatlanta.com/Porsche-914-Fus...1461231610.html and based on my user manual, I think the location of all the icons is backwards. i.e. The leftmost icon should actually be the rightmost icon, the second leftmost should be the second rightmost, and so on. If that is accurate, I guess I could just install the cover upside down, but to start I just wanted to make sure that I had my facts correct. By the way, the photo on the website is not just upside down because there are numbers on the cover that are only right side up in the orientation as shown. Second question - should this cover snap into place? Regardless of orientation, I can't seem to get it to snap in anywhere. Thanks in advance! |
ejm |
I can see the light at the end of the tunnel ![]() ![]() ![]() ![]() Group: Members Posts: 2,695 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None ![]() |
The cover is shown reversed. The light icons will be on the left when installed and the numbers will be upside down. Engage the edge closer to you then rotate the forward edge into place.
Olympic 914 |
![]() ![]() ![]() Group: Members Posts: 1,679 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States ![]() ![]() |
The cover is shown reversed. The light icons will be on the left when installed and the numbers will be upside down. Engage the edge closer to you then rotate the forward edge into place. Maybe it's designed that way so when you are laying on your back looking up at it the icons are readable and correct. A very uncomfortable position..... |
Lo-Fi Version | Time is now: 13th June 2024 - 11:35 PM |
