Major Cooling System issues, Flap system removed by PO |
Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
Gatornapper |
Aug 20 2019, 08:31 PM
Guys all - I hear you, loud and clear.
Engine will not only be dropped and flaps added before it is put back, it will be rebuilt. Y'all misread me - no fear of dropping engine - have lift & everything I need to do it. No compression in 3 & 4 - 60 psi. Was 90/100 4,000 miles ago when checked at local dealer. Only 100 & 102 in 1 and 2....same as dealer had. Today I pulled out a cubic foot of mouse nest on the right on top of 3 & 4. Will post pic tomorrow since I have to upload it first to a pic website. Left side clean and open, right side now clean and open. Will try to scope oil cooler tomorrow, but right now it's a moot point. Huge decision on engine rebuild though.....for my Weber 44's, increasing bore & stroke, adding cam? or for the original D-jet? I'll address that on my other thread. Thanks again everyone for all the help and great advice. GN |
Superhawk996 |
Aug 21 2019, 04:26 AM
914 Guru Group: Members Posts: 5,904 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
No compression in 3 & 4 - 60 psi. Was 90/100 4,000 miles ago when checked at local dealer. Only 100 & 102 in 1 and 2....same as dealer had. Today I pulled out a cubic foot of mouse nest on the right on top of 3 & 4. Will post pic tomorrow since I have to upload it first to a pic website. Left side clean and open, right side now clean and open. Will try to scope oil cooler tomorrow, but right now it's a moot point. GN Oh Dude! So sorry to hear about cyl #3 & 4. Likely the overheating mouse nest lead to catastrophic sealing issue on that side. Really makes me mad that the dealer wouldn't take a peek in there. Especially in an age of $100 bore scopes. Why is everyone now a days just trying to get by on the bare minimum? I recently tore down GA000099 and yup, a huge mouse next in #1/2 and the oil cooler is nearly full restriction due to grease & cottonwood fluff. Rebuilds aren't hard - just take your time. With respect to the CV's getting grease everywhere . . . . put a 1 gallon Ziplock freezer bag (or better - two for durability) over them immediately upon disconnect. Tape it closed. Grease contamination and transfer to everything else is solved or greatly minimized. Do not pull the rear axle stub and roll the vehicle or the wheel bearings will be destroyed. Bungee works to keep axles from flopping around if you need to roll with CV's in place. |
Lo-Fi Version | Time is now: 11th June 2024 - 03:16 AM |
