| Qarl |
May 21 2003, 05:46 PM
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Okay... I'm going to refinish/restore a set of early 911 hubs and stub axles. The set I have is in very good condition, the splines and studs are all great. There is some slight surface rust on the cast metal part of the stub axle. I figure I'm going soak the part in marine clean first, then tape up the splines and bead blast the whole stub axle.
Then what? How should I protect the freshly blasted metal. I know the splines of the hub will be protected with grease... How did they come new from the factory? Thanks, |
| Mueller |
May 21 2003, 06:17 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Por-15 works nice on those parts. I'm not too sure if the factory parts had been powdercoated or if they used a thick paint.
Qarl Refinishing hubs and stubs May 21 2003, 05:46 PM
Gint I did the same thing to the last car I had. I pow... May 21 2003, 07:22 PM
Qarl What about cosmoline?
Could the factory parts h... May 21 2003, 08:31 PM
Lawrence914-6 Yeah, Mike... but you do your own powdercoating in... May 22 2003, 11:15 AM
Gint :D May 22 2003, 03:19 PM
campbellcj You wouldn't believe how nasty the arms and st... May 22 2003, 03:25 PM
Qarl Chris:
What did you do to your hubs to fix things... May 22 2003, 04:22 PM
Bleyseng cosmoline is used was used to preserve parts as it... May 22 2003, 05:41 PM![]() ![]() |
Lo-Fi Version | Time is now: 16th June 2026 - 06:26 AM |
