Canton 10 qt. oil tank level w/fron mounted cooler, What a safe number of quarts for 2.7 6cyl |
AnthonyM |
Aug 18 2019, 04:27 PM
Newbie Group: Members Posts: 38 Joined: 8-December 12 From: Hudson, OH Member No.: 15,243 Region Association: North East States |
Just purchased a non running 914-6 GT with a Canton front mounted oil tank and Mocal front mounted oil cooler (25 row .50L capacity). I know that 9 quarts is probably a safe capacity for a standard set up with a factory 914-6 oil tank, but how many quarts should I use for safe operation with this set up? No dip stick in oil tank. This will be a street car to begin with. The engine is a 2.7 with CIS.
sixnotfour |
Aug 24 2019, 02:37 PM
914 Wizard Group: Members Posts: 10,433 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
that vent you need a catch tank, untill you get the level sorted, or your trunk will be well lubed.....
crank it over check the level add as necessary....remeber it will expand a bit when hot... |
Lo-Fi Version | Time is now: 2nd June 2024 - 03:00 AM |
