| Chris H. |
Aug 24 2019, 03:28 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,111 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Had the weirdest thing happen today...hoping someone knows a lot more than I do about the ignition tumbler/switch/etc.
Ran a bunch of errands in the 914, stopped at several places. At the last stop I came out to the car, inserted the key in the ignition switch, and it was like it was the wrong key. The mechanism did not push inward as usual, and the key would not turn at all no matter how much I messed with it. I've had the thing 17 years and never had an issue with the mechanism before, and it's the same key as always. I had to pull the switch out entirely (steering wheel off, etc) and pop out the lock to start it. Luckily I was only a few blocks from home. Anyone ever have this happen? Here are some pics of the whole mechanism. Anything missing or look weird? Anyone know what that little pin is for? It was in the bottom of the cylinder Hope someone knows how to fix this...is it possible the wafers got bent inside the key lock and it needs to be re-keyed? I'm at a loss... (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
| 76-914 |
Aug 24 2019, 04:37 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,991 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Sounds like a wafer(s) went south. Good place to start. IIRC, that little pin has something to do with the steering lock. 75/76?
Chris H. Ignition key just stopped working! Aug 24 2019, 03:28 PM
SirAndy Did you get into the wrong car?
:confused: Aug 24 2019, 03:30 PM
Chris H. Unlikely Andy, but good thinking :D :idea: Aug 24 2019, 03:32 PM
Chris H. Yeah that's what I'm thinking Kent. I hav... Aug 24 2019, 04:47 PM
bbrock I think that pin is the suspect. I can't reme... Aug 24 2019, 05:19 PM
Chris H. Interesting...I'll check that out Brent. Aug 24 2019, 05:32 PM
Chris H. So I cleaned it all up...there was some gunk in th... Aug 24 2019, 06:37 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th November 2026 - 10:35 PM |
