| Ed_Turbo |
Aug 25 2019, 03:22 PM
Member ![]() ![]() Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
Hello! I am trying to ID these wires:
![]() I am not good at wiring diagrams and I found no luck researching this topic (IMG:style_emoticons/default/confused24.gif) Enlighten me with your Jedi wiring knowledge @JeffBowlsby @Dave_Darling and anyone else who are pros at wiring 914’s. -Ed Attached thumbnail(s) |
| jcd914 |
Aug 25 2019, 06:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,098 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
I don't have details on how it is supposed to work and the diagrams I have don't have the relay and wiring on them.
The general consensus is that it more often doesn't work correctly. It is supposed to turn on the seatbelt warning light on the dash AND lock out the starter if the seatbelts are not fastened. There is a pressure switch in the passenger seat and there are switches in each seatbelt receiver to determine if the belts are buckled. When you try to start the engine if your seatbelt is not fastened the starter won't crank and if you have a passenger their seatbelt has to be fastened too. The two important wires are the large yellow and yellow with red stripe. These are the power from the ignition switch to the starter and should be pulled from the relay socket and securly connected together. That way when one of the seatbelt receiver switches, seat pressure switch or relay fail you will still be able to start your car. Jim |
Ed_Turbo Seat Belt Relay Wiring Aug 25 2019, 03:22 PM
jim_hoyland :agree:
I would like to know how the relay works... Aug 25 2019, 06:00 PM
Chi-town The ones with the wire nuts appear to be the buckl... Aug 25 2019, 06:46 PM
FlacaProductions Connect the black wire to the black/red stripe and... Aug 25 2019, 06:49 PM
FlacaProductions Here's a shot that I've saved from here th... Aug 25 2019, 06:50 PM
FlacaProductions @jcd914 - I think you mean Yellow and Yellow/red ... Aug 25 2019, 06:57 PM
jcd914
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 25 2019, 07:03 PM
JeffBowlsby It’s not a relay it’s a logic box. Diagrammed... Aug 25 2019, 07:01 PM
jcd914
It’s not a relay it’s a logic box. Diagramme... Aug 25 2019, 07:10 PM
ClayPerrine
It’s not a relay it’s a logic box. Diagramm... Aug 25 2019, 07:57 PM
jim_hoyland
It’s not a relay it’s a logic box. Diagramme... Aug 25 2019, 08:28 PM
Rand Cut it all. Join the big yellow because it's t... Aug 25 2019, 08:30 PM
JeffBowlsby Just bypass it by mating the two big yellow wires.... Aug 26 2019, 05:58 AM
porschetub Mines bypassed but I would still like to get rid o... Aug 26 2019, 02:06 PM
914werke Cut it all. Run away laughing happily.
:D @R... Aug 26 2019, 02:34 PM![]() ![]() |
Lo-Fi Version | Time is now: 30th October 2026 - 04:48 PM |
