| Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,290 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
| Gatornapper |
Aug 25 2019, 11:35 AM
The PO responded to my query and insists that he did not remove the flap system. That means he owned & drove the car from 2001 to 2006 without the flaps - with no overheating......
Which raises a whole new set of questions.....also learned this was his 3rd 914..... How was car driven for over 5 years with no flaps and no over-heating? I guess we'll never know....... GN |
| Superhawk996 |
Aug 25 2019, 11:45 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The PO responded to my query and insists that he did not remove the flap system. That means he owned & drove the car from 2001 to 2006 without the flaps - with no overheating...... Which raises a whole new set of questions.....also learned this was his 3rd 914..... How was car driven for over 5 years with no flaps and no over-heating? I guess we'll never know....... GN You may find out when you pull the tin. Wouldn't be surprised to find a mouse house or clogged oil cooler. Also who's to say he was paying attention and didn't overheat it or the previously mentioned girlfriend? Maybe he only drove it a few miles to Dairy Queen for an ice cream only once a year. Who really knows? That is why I make it a personal principle to tear down every engine as if it was a core. Heck I got my original engine (the one without flaps) running before I tore the car apart but seriously had no idea of how much rust and muck was sitting in the sump. No idea that the crank was already 0.010" undersize and scored. It would have run for a while but would have eventually destroyed itself at the most inopportune time. These cars are now 40 - 50 years old and should be assessed as such . . . probably worn out. Had I pulled the engine apart and found it to be pristine, no big deal. Fresh gaskets and it would have gone back together. Ah . . . if only that had been the case. |
| Gatornapper |
Aug 25 2019, 11:54 AM
SH -
Totally get it. But, mine does only have 60k miles on it.....pretty sure that's fairly accurate. Debating opening the case if I do the C's & P's.......kinda know I should, but also know it will likely lead to spending money that might not be necessary - like a cam for the carbs..... GN The PO responded to my query and insists that he did not remove the flap system. That means he owned & drove the car from 2001 to 2006 without the flaps - with no overheating...... Which raises a whole new set of questions.....also learned this was his 3rd 914..... How was car driven for over 5 years with no flaps and no over-heating? I guess we'll never know....... GN You may find out when you pull the tin. Wouldn't be surprised to find a mouse house or clogged oil cooler. Also who's to say he was paying attention and didn't overheat it or the previously mentioned girlfriend? Maybe he only drove it a few miles to Dairy Queen for an ice cream only once a year. Who really knows? That is why I make it a personal principle to tear down every engine as if it was a core. Heck I got my original engine (the one without flaps) running before I tore the car apart but seriously had no idea of how much rust and muck was sitting in the sump. No idea that the crank was already 0.010" undersize and scored. It would have run for a while but would have eventually destroyed itself at the most inopportune time. These cars are now 40 - 50 years old and should be assessed as such . . . probably worn out. Had I pulled the engine apart and found it to be pristine, no big deal. Fresh gaskets and it would have gone back together. Ah . . . if only that had been the case. |
| Superhawk996 |
Aug 25 2019, 01:32 PM
SH - Totally get it. But, mine does only have 60k miles on it.....pretty sure that's fairly accurate. Debating opening the case if I do the C's & P's.......kinda know I should, but also know it will likely lead to spending money that might not be necessary - like a cam for the carbs..... Call me a doubting Thomas but I think very few of these cars have accurate mileage unless they can be backed up with records from new. Trans cables are easily disconnected. Speedo/ODO is an easy swap. Think about it. Cars 40 years old with an average of only 1.5K miles per year? Not likely. I know some are low mileage originals out there, but, most aren't. Mine had ODO at 60K but shows every sign of that not being correct. With respect to opening the case, any consequences of "while I'm in there" syndrome of swapping to 102mm pistons, stroker cranks, etc. are on you. Granted a fresh set of bearings (crank, rods, and cam) and a Gasket kit will set you back $250, but, if everything else checks out there is no harm done in putting it back together with nothing more than fresh gaskets if it really is OK and low mileage. I'm currently rebuilding GA000099 and it indeed a low mileage engine with no real wear on the pistons, or cylinders, but the ring end gaps are out of spec and showing some wear. Even at 60K you're likely to find that you need a cam. The design of these cams is such that a single lobe is shared with two cylinders. That essentially leads to a doubling of wear at the center of the lobe. Found the stock cam in GA000099 and as stated, the lobes are showing wear even though the P&C do not. I'd just suggest that you evaluate as you go and adapt accordingly. |
| Gatornapper |
Aug 25 2019, 07:24 PM
SH -
Only makes sense, I agree - especially since I did not know about the cam load. I do know this: Original Owner's Manual shows car was delivered on 1/27/76, and has dealer service stamped showing 13,971 miles on 1/25/1977 in Buena Park, CA. I also have Porsche dealer invoice showing 56,496 on 8/31/2001. Another showing 58,537 on 11/29/2002. That's 44,500 miles in 25+ years, or only 1,700 miles/year. Extremely low UNLESS the car sat for a number of years. Which is also not unusual for these cars. Car indicated 60,600 on 9/22/17 when I purchased it and had been sitting in one place in my friends barn for 12 years. It sat in my garage for almost 2 years. 14 total recent years, zero miles. So between '01 and '06 it was driven 4k miles in the last full year it was driven. Wear on the car is commensurate with a 60k car. Interior is very nice, so are pedals. But as you say, who knows? Best to check all when engine is out. If cam is worn, I'm going with a cam for the Weber 44's. GN SH - Totally get it. But, mine does only have 60k miles on it.....pretty sure that's fairly accurate. Debating opening the case if I do the C's & P's.......kinda know I should, but also know it will likely lead to spending money that might not be necessary - like a cam for the carbs..... Call me a doubting Thomas but I think very few of these cars have accurate mileage unless they can be backed up with records from new. Trans cables are easily disconnected. Speedo/ODO is an easy swap. Think about it. Cars 40 years old with an average of only 1.5K miles per year? Not likely. I know some are low mileage originals out there, but, most aren't. Mine had ODO at 60K but shows every sign of that not being correct. With respect to opening the case, any consequences of "while I'm in there" syndrome of swapping to 102mm pistons, stroker cranks, etc. are on you. Granted a fresh set of bearings (crank, rods, and cam) and a Gasket kit will set you back $250, but, if everything else checks out there is no harm done in putting it back together with nothing more than fresh gaskets if it really is OK and low mileage. I'm currently rebuilding GA000099 and it indeed a low mileage engine with no real wear on the pistons, or cylinders, but the ring end gaps are out of spec and showing some wear. Even at 60K you're likely to find that you need a cam. The design of these cams is such that a single lobe is shared with two cylinders. That essentially leads to a doubling of wear at the center of the lobe. Found the stock cam in GA000099 and as stated, the lobes are showing wear even though the P&C do not. I'd just suggest that you evaluate as you go and adapt accordingly. |
| Superhawk996 |
Aug 26 2019, 06:04 AM
SH - Only makes sense, I agree - especially since I did not know about the cam load. I do know this: Original Owner's Manual shows car was delivered on 1/27/76, and has dealer service stamped showing 13,971 miles on 1/25/1977 in Buena Park, CA. I also have Porsche dealer invoice showing 56,496 on 8/31/2001. Another showing 58,537 on 11/29/2002. That's 44,500 miles in 25+ years, or only 1,700 miles/year. Extremely low UNLESS the car sat for a number of years. Which is also not unusual for these cars. Car indicated 60,600 on 9/22/17 when I purchased it and had been sitting in one place in my friends barn for 12 years. It sat in my garage for almost 2 years. 14 total recent years, zero miles. So between '01 and '06 it was driven 4k miles in the last full year it was driven. Wear on the car is commensurate with a 60k car. Interior is very nice, so are pedals. But as you say, who knows? Best to check all when engine is out. If cam is worn, I'm going with a cam for the Weber 44's. GN SH - Totally get it. But, mine does only have 60k miles on it.....pretty sure that's fairly accurate. Debating opening the case if I do the C's & P's.......kinda know I should, but also know it will likely lead to spending money that might not be necessary - like a cam for the carbs..... Call me a doubting Thomas but I think very few of these cars have accurate mileage unless they can be backed up with records from new. Trans cables are easily disconnected. Speedo/ODO is an easy swap. Think about it. Cars 40 years old with an average of only 1.5K miles per year? Not likely. I know some are low mileage originals out there, but, most aren't. Mine had ODO at 60K but shows every sign of that not being correct. With respect to opening the case, any consequences of "while I'm in there" syndrome of swapping to 102mm pistons, stroker cranks, etc. are on you. Granted a fresh set of bearings (crank, rods, and cam) and a Gasket kit will set you back $250, but, if everything else checks out there is no harm done in putting it back together with nothing more than fresh gaskets if it really is OK and low mileage. I'm currently rebuilding GA000099 and it indeed a low mileage engine with no real wear on the pistons, or cylinders, but the ring end gaps are out of spec and showing some wear. Even at 60K you're likely to find that you need a cam. The design of these cams is such that a single lobe is shared with two cylinders. That essentially leads to a doubling of wear at the center of the lobe. Found the stock cam in GA000099 and as stated, the lobes are showing wear even though the P&C do not. I'd just suggest that you evaluate as you go and adapt accordingly. You may indeed be correct that it is a true 60K car then. That is awesome. So many have zero records - your're well ahead in that regard. when you do the top end, pull the lifters out - you can probably use a borescope to get a good look at the cam lobes. If they are hollowed out at the center where the lifter paths overlap, you'll need a cam. If not, you could use that to justify not splitting the case. One thing to keep in mind - cars of this era were not designed to life cycles of 150K miles like they are today. Probably more like an optimistic 100K at best. If you plan to drive daily (or hard)- know that you may already be 6/10 worn. In theory, a plain bearing has a near infinite life as long as oil is kept clean and constant oil pressure is maintained. The main problem is that you have no flaps, and have already experienced overheating yourself. This greatly thinned oil viscosity and dropped oil pressure and will have taken some unknown % bearing life away. It is always a bit hard to know if oil was kept clean but again with some records you at least have some insight on early life maintenance. The main thing I'm suspicious of is why someone would bother to get in there and ONLY remove the flaps. The fact that it has Webers says someones been mucking around somewhere in that 60K miles for some reason. Maybe it was running lean and/or hot and some shade tree pulled FI for Webers and though pulling the flaps would help. Not being overly critical here - I myself pulled FI on my original car for Webers (young and dumb, didn't understand FI yet). In my opinion, it is all the unknowns that would make me split the case regardless. Then I KNOW what I have . . . but I'm OCD that way. (IMG:style_emoticons/default/rolleyes.gif) I'll post up a picture later tonight of GA000099 stock cam and the lobe wear so that you know what you're looking for. Get in touch with Clay -- per previous post he has flaps. |
| Gatornapper |
Aug 26 2019, 09:40 AM
Perfect. I have the scope - will do this for sure, and that will determine what I do.
If cam looks good, and I can get another 30k out of engine before going inside, I'll just do the top end. Plan is coming together. My winter project. Thanks....... GN "when you do the top end, pull the lifters out - you can probably use a borescope to get a good look at the cam lobes. If they are hollowed out at the center where the lifter paths overlap, you'll need a cam. If not, you could use that to justify not splitting the case. " |
Gatornapper Major Cooling System issues Aug 20 2019, 09:29 AM
Mblizzard Did you scope the oil cooler to ensure that it was... Aug 20 2019, 10:14 AM
malcolm2
Did you scope the oil cooler to ensure that it wa... Aug 20 2019, 11:00 AM
Mblizzard
[quote name='Mblizzard' post='2739976' date='Aug ... Aug 20 2019, 11:03 AM
Ansbacher You sound a bit like a doctor that needs to perfor... Aug 20 2019, 10:24 AM
Porschef You may want to consider dropping the engine. Heck... Aug 20 2019, 10:27 AM
malcolm2
You may want to consider dropping the engine. Hec... Aug 20 2019, 10:59 AM
SirAndy You may want to consider dropping the engine. Heck... Aug 20 2019, 11:27 AM
cuddy_k :agree:
Trying to remove the tins with the engin... Aug 20 2019, 10:40 AM
rhodyguy Remove the carbs as a unit not to include the inta... Aug 20 2019, 11:53 AM
malcolm2 https://www.ratwell.com/technical/Thermostats.html... Aug 20 2019, 12:14 PM
dr914@autoatlanta.com you MUST reinstall the flaps!!!!... Aug 20 2019, 12:24 PM
Superhawk996 I sort of wonder how this whole pull the flaps myt... Aug 20 2019, 04:21 PM
bretth
I sort of wonder how this whole pull the flaps my... Aug 20 2019, 04:31 PM
porschetub Do it once and do it right,good chance to check ev... Aug 20 2019, 04:34 PM
rhodyguy This is how it starts. 'While you're in th... Aug 20 2019, 06:46 PM
Spoke You need to drop the engine. You have enough stuff... Aug 20 2019, 07:20 PM
ClayPerrine Drop the motor. It's easy.
Once its out, then... Aug 20 2019, 08:02 PM
Gatornapper Guys all - I hear you, loud and clear.
Engine w... Aug 20 2019, 08:31 PM
Superhawk996
No compression in 3 & 4 - 60 psi. Was 90/1... Aug 21 2019, 04:26 AM
Gatornapper Superhawk -
Was MY BAD, not the dealer who check... Aug 21 2019, 05:33 AM
Mblizzard
Superhawk -
Was MY BAD, not the dealer who chec... Aug 21 2019, 07:05 AM
falcor75 When you've pulled the driveshafts from the ge... Aug 21 2019, 05:39 AM
Gatornapper Great tip! I use plastic bags for similar con... Aug 21 2019, 12:30 PM
Superhawk996 My bad - jumping to a conclusion. :(
I read t... Aug 21 2019, 07:19 AM
Gatornapper SH -
You didn't jump to conclusions. In desi... Aug 21 2019, 07:03 PM
Gatornapper Update:
Engine was cold yesterday when I took com... Aug 21 2019, 07:01 PM
Gatornapper Ran engine today in 93* ambient until gauge was ju... Aug 22 2019, 01:42 PM
Gatornapper Still wondering if there is a way to see the top o... Aug 23 2019, 12:26 PM
jcd914
Still wondering if there is a way to see the top ... Aug 23 2019, 12:32 PM
rhodyguy I think you're getting ahead of yourself. You ... Aug 23 2019, 01:14 PM
Gatornapper Rhodyguy -
You are right on.
So, can I install t... Aug 23 2019, 06:29 PM
Gatornapper While it is clear that I have to put the flaps ... Aug 24 2019, 05:07 AM
Rand
While it is clear that I have to put the flaps ... Aug 24 2019, 07:52 AM
Superhawk996
[quote name='Gatornapper' post='2741106' date='Au... Aug 24 2019, 09:35 AM
Gatornapper Loud and clear, SH.
Do I HAVE to drop the engine ... Aug 24 2019, 09:45 AM
Porschef There’s bugging a previous owner with a multitu... Aug 24 2019, 07:16 AM
Gatornapper Great idea, thank you, but "Been there, done ... Aug 24 2019, 09:34 AM
Garland Here’s a shot with the shroud and heater tins re... Aug 24 2019, 07:49 AM
rhodyguy WHY the P.O. removed the system is not relevant to... Aug 24 2019, 08:20 AM
Gatornapper FYI - dropping the engine is no problem in and of ... Aug 24 2019, 09:51 AM
Rand
FYI - dropping the engine is no problem in and of... Aug 24 2019, 09:56 AM
Superhawk996 On a 914 it is much easier to just drop the engine... Aug 24 2019, 09:53 AM
ClayPerrine
In the case of the flaps, you'll need to pull... Aug 24 2019, 09:55 PM
Gatornapper Clay -
Thanks - I'm sold. Think the motorcyc... Aug 25 2019, 07:15 AM
Superhawk996 Drop engine - then roll car off host to make room ... Aug 24 2019, 09:59 AM
Rand Love your style. That's how most of us get it ... Aug 24 2019, 10:05 AM
rhodyguy Unless the CVs are stuck/bonded to the rear of the... Aug 24 2019, 10:14 AM
Superhawk996 :agree:
Pulling the rear stub carries some risk ... Aug 24 2019, 10:16 AM
cuddy_k I suggest you try to do this with the engine in th... Aug 24 2019, 10:35 AM
Superhawk996
I suggest you try to do this with the engine in t... Aug 24 2019, 10:38 AM
cuddy_k :) we Joke because we care. We’ve all been ther... Aug 24 2019, 10:52 AM
SirAndy :) we Joke because we care. We’ve all been ther... Aug 24 2019, 12:26 PM
Gatornapper Guys -
Got the message loud and clear.
"A... Aug 24 2019, 08:36 PM
rhodyguy If you're set on not dropping the engine, Step... Aug 24 2019, 12:56 PM
SirAndy Engine + trans drop is less than an hour.
You don... Aug 24 2019, 02:53 PM
rhodyguy Cleaning the engine compartment is quick and easy ... Aug 24 2019, 10:03 PM
Gatornapper I have the full and true story on the FI-Weber con... Aug 26 2019, 07:11 AM
Al Meredith Here in the South (Atlanta) I have built several H... Aug 25 2019, 12:07 PM
Gatornapper Al - totally understand - flaps ON THE WAY from an... Aug 25 2019, 01:17 PM
ClayPerrine
Here in the South (Atlanta) I have built several ... Aug 25 2019, 08:07 PM
Gatornapper Totally remember all cars were good for 100k mis. ... Aug 26 2019, 07:20 AM
wndsrfr
Totally remember all cars were good for 100k mis.... Aug 26 2019, 08:09 AM
Gatornapper John -
Like here:
https://aapistons.com/collecti... Aug 26 2019, 09:18 AM
Gatornapper John -
Does the bore for the 96mm pistons give yo... Aug 26 2019, 09:26 AM
ChrisFoley I just pulled the tin off an engine that appeared ... Aug 26 2019, 11:02 AM
Gatornapper Chris -
THANK YOU FOR THIS POST! VERY educat... Aug 26 2019, 07:07 PM
rhodyguy How was the vane on dr side positioned? Aug 26 2019, 02:37 PM
ChrisFoley No, I have the engine out of the car. I wouldn... Aug 26 2019, 08:30 PM
Gatornapper Chris -
Thank you. I've never seen your oil ... Aug 27 2019, 05:41 AM
ChrisFoley
Chris -
Thank you. I've never seen your oil... Aug 27 2019, 07:24 AM
Gatornapper Thanks, Chris.
"Be careful with synthetic oi... Aug 27 2019, 07:23 PM
ChrisFoley
"High oil pressure = no oil moving in t... Aug 28 2019, 05:18 AM
Gatornapper Cool! Great design...
The stock pressure re... Aug 28 2019, 09:40 AM
Superhawk996 I’ll defer to Chris on this for racing applicati... Aug 28 2019, 10:38 AM
ChrisFoley
Keep in mind, hot oil is usually not high pressur... Aug 28 2019, 11:11 AM
Superhawk996 Just want to be clear my intent isn’t to start a... Aug 28 2019, 12:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 01:12 PM |
