| advman89 |
Jul 22 2019, 09:11 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest
Does this look correct? This is on the passenger side, in front of the rear tire. I had been looking for something like the Mahle canister.
(Sorry for the bad pic!) Pelican sent me a Mahle filter...round, not square...can I use this? Part# 311-133-511-D-M67 Mahle KL 11 OF 1971 Car, 2.0 with some various bits from a 1975...just trying to sort what's what. |
| VaccaRabite |
Aug 26 2019, 10:10 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Yes, but not in the engine bay!
It has to be low - lower then the gas tank or there isnt any fuel gravity fed to the pump. Its own issue. most people relocate them to the front trunk under the gas tank, or under the front trunk near the steering rack. The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. Zach |
advman89 Found the fuel filter.... Jul 22 2019, 09:11 PM
JawjaPorsche The original location of the fuel pump and filter ... Jul 23 2019, 04:32 AM
advman89 Thank you...
Guess that full fuel line hose repla... Jul 23 2019, 08:27 PM
advman89 Ugh.
I'm hoping someone can help!
Where... Aug 25 2019, 10:31 AM
dabird Take the plate off that's covering the steerin... Aug 25 2019, 10:51 AM
SirAndy On a '71 the fuel pump is under the pass. side... Aug 25 2019, 11:06 AM
advman89 Thanks everyone. This car is so much the flipside ... Aug 26 2019, 09:45 AM
SirAndy The factory changed the location in 75-76 cars and... Aug 26 2019, 11:55 AM
ClayPerrine
[quote name='VaccaRabite' post='2741743' date='Au... Aug 26 2019, 12:03 PM
Jamie
The factory changed the location in 75-76 cars an... Aug 26 2019, 05:25 PM
advman89 Plan is to replace all the lines...tank to injecto... Aug 26 2019, 12:30 PM
advman89 Found. It's under the car, by the rear passeng... Aug 26 2019, 06:21 PM
tmc914 In the front near the front axle there is a panel ... Aug 26 2019, 09:16 PM
914werke What material did the factory use for fuel lines ... Aug 27 2019, 10:00 AM
VaccaRabite
What material did the factory use for fuel lines... Aug 27 2019, 11:10 AM
ClayPerrine
The lines in my BMW '75 2002 were the same e... Aug 29 2019, 08:51 PM
914werke Nope. I dont know what went on with your car Zach ... Aug 27 2019, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 11:42 PM |
