| Gatornapper |
Aug 20 2019, 09:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,290 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States
Need the Brain Trust help again - big time.
Up to now, nothing I've faced in getting this sweet 14 running and back on the road has been major or disheartening. Lots of new stuff, running pretty good but not perfect, etc. That just changed. Ever since getting the engine running a few months ago, I was concerned that it took a long time to warm up. My first 1 hour + drive was last week - and temps got too high for my comfort - about 1/4" from red line. So I've been drilling down on that issue. For one thing, car sat in a barn (new one) for 12 years - so I wondered about mice nests above the cylinders from the day I bought the car. Yesterday with my scope I found, yes, they are there between the cylinders - at least between 2 & 4. I think I can get them out with a small vacuum through the spark plug holes in the top tins.....we'll see. Due to total ignorance of 914's and VW engines, I know nothing of the air ducting system, but in the learning process, and thanks to anderssj , I find the whole flap/door system and its controls are missing. Gone. So I can only assume that the PO removed them due to problems with overheating. Stupid move for sure. I have to correct that. I understand that move itself could cause overheating. I dread pulling the carbs, intake manifolds, distributor and other stuff to get the top tins off. Plan is to see if I can get the mouse stuff off the cylinders with a small vacuum, make sure all is clean with my scope. If successful, I'll then drive the car and see if it still gets too hot. If I can't get the debris removed with vacuum, I know I have to pull the top tins. But I am told that not having the flap system itself could cause overheating. So I have to get that system installed and working. Yes, I know the many potential causes of overheating like improper timing, plugs, etc. Timing good, plugs good - new. Valves adjusted by dealer about 1,500 miles ago. Got a lot of work ahead - all when I wanted to have the car ready for the big PCA 9/14 914 Vintage Drive. Any help and advice is of course, as always, appreciated. GN |
| ChrisFoley |
Aug 26 2019, 11:02 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
I just pulled the tin off an engine that appeared to have no cooling flaps. The thermostat and crossbar were removed. I tried to pull the shroud off before removing the cylinder tin but it hung up on the passenger side. I was able to look inside and could see that the oil cooler flap was in place, riveted down at the back. That's the warm position, which directs some of the air to the cooler. This engine runs quite hot so I was expecting no flap at all.
Owner has documented 250F in 90+ degree weather climbing hills at 80 mph. Next step is to install one of my remote oil cooler kits so he can run his AC without overheating the engine. |
Gatornapper Major Cooling System issues Aug 20 2019, 09:29 AM
Mblizzard Did you scope the oil cooler to ensure that it was... Aug 20 2019, 10:14 AM
malcolm2
Did you scope the oil cooler to ensure that it wa... Aug 20 2019, 11:00 AM
Mblizzard
[quote name='Mblizzard' post='2739976' date='Aug ... Aug 20 2019, 11:03 AM
Ansbacher You sound a bit like a doctor that needs to perfor... Aug 20 2019, 10:24 AM
Porschef You may want to consider dropping the engine. Heck... Aug 20 2019, 10:27 AM
malcolm2
You may want to consider dropping the engine. Hec... Aug 20 2019, 10:59 AM
SirAndy You may want to consider dropping the engine. Heck... Aug 20 2019, 11:27 AM
cuddy_k :agree:
Trying to remove the tins with the engin... Aug 20 2019, 10:40 AM
rhodyguy Remove the carbs as a unit not to include the inta... Aug 20 2019, 11:53 AM
malcolm2 https://www.ratwell.com/technical/Thermostats.html... Aug 20 2019, 12:14 PM
dr914@autoatlanta.com you MUST reinstall the flaps!!!!... Aug 20 2019, 12:24 PM
Superhawk996 I sort of wonder how this whole pull the flaps myt... Aug 20 2019, 04:21 PM
bretth
I sort of wonder how this whole pull the flaps my... Aug 20 2019, 04:31 PM
porschetub Do it once and do it right,good chance to check ev... Aug 20 2019, 04:34 PM
rhodyguy This is how it starts. 'While you're in th... Aug 20 2019, 06:46 PM
Spoke You need to drop the engine. You have enough stuff... Aug 20 2019, 07:20 PM
ClayPerrine Drop the motor. It's easy.
Once its out, then... Aug 20 2019, 08:02 PM
Gatornapper Guys all - I hear you, loud and clear.
Engine w... Aug 20 2019, 08:31 PM
Superhawk996
No compression in 3 & 4 - 60 psi. Was 90/1... Aug 21 2019, 04:26 AM
Gatornapper Superhawk -
Was MY BAD, not the dealer who check... Aug 21 2019, 05:33 AM
Mblizzard
Superhawk -
Was MY BAD, not the dealer who chec... Aug 21 2019, 07:05 AM
falcor75 When you've pulled the driveshafts from the ge... Aug 21 2019, 05:39 AM
Gatornapper Great tip! I use plastic bags for similar con... Aug 21 2019, 12:30 PM
Superhawk996 My bad - jumping to a conclusion. :(
I read t... Aug 21 2019, 07:19 AM
Gatornapper SH -
You didn't jump to conclusions. In desi... Aug 21 2019, 07:03 PM
Gatornapper Update:
Engine was cold yesterday when I took com... Aug 21 2019, 07:01 PM
Gatornapper Ran engine today in 93* ambient until gauge was ju... Aug 22 2019, 01:42 PM
Gatornapper Still wondering if there is a way to see the top o... Aug 23 2019, 12:26 PM
jcd914
Still wondering if there is a way to see the top ... Aug 23 2019, 12:32 PM
rhodyguy I think you're getting ahead of yourself. You ... Aug 23 2019, 01:14 PM
Gatornapper Rhodyguy -
You are right on.
So, can I install t... Aug 23 2019, 06:29 PM
Gatornapper While it is clear that I have to put the flaps ... Aug 24 2019, 05:07 AM
Rand
While it is clear that I have to put the flaps ... Aug 24 2019, 07:52 AM
Superhawk996
[quote name='Gatornapper' post='2741106' date='Au... Aug 24 2019, 09:35 AM
Gatornapper Loud and clear, SH.
Do I HAVE to drop the engine ... Aug 24 2019, 09:45 AM
Porschef There’s bugging a previous owner with a multitu... Aug 24 2019, 07:16 AM
Gatornapper Great idea, thank you, but "Been there, done ... Aug 24 2019, 09:34 AM
Garland Here’s a shot with the shroud and heater tins re... Aug 24 2019, 07:49 AM
rhodyguy WHY the P.O. removed the system is not relevant to... Aug 24 2019, 08:20 AM
Gatornapper FYI - dropping the engine is no problem in and of ... Aug 24 2019, 09:51 AM
Rand
FYI - dropping the engine is no problem in and of... Aug 24 2019, 09:56 AM
Superhawk996 On a 914 it is much easier to just drop the engine... Aug 24 2019, 09:53 AM
ClayPerrine
In the case of the flaps, you'll need to pull... Aug 24 2019, 09:55 PM
Gatornapper Clay -
Thanks - I'm sold. Think the motorcyc... Aug 25 2019, 07:15 AM
Superhawk996 Drop engine - then roll car off host to make room ... Aug 24 2019, 09:59 AM
Rand Love your style. That's how most of us get it ... Aug 24 2019, 10:05 AM
rhodyguy Unless the CVs are stuck/bonded to the rear of the... Aug 24 2019, 10:14 AM
Superhawk996 :agree:
Pulling the rear stub carries some risk ... Aug 24 2019, 10:16 AM
cuddy_k I suggest you try to do this with the engine in th... Aug 24 2019, 10:35 AM
Superhawk996
I suggest you try to do this with the engine in t... Aug 24 2019, 10:38 AM
cuddy_k :) we Joke because we care. We’ve all been ther... Aug 24 2019, 10:52 AM
SirAndy :) we Joke because we care. We’ve all been ther... Aug 24 2019, 12:26 PM
Gatornapper Guys -
Got the message loud and clear.
"A... Aug 24 2019, 08:36 PM
rhodyguy If you're set on not dropping the engine, Step... Aug 24 2019, 12:56 PM
SirAndy Engine + trans drop is less than an hour.
You don... Aug 24 2019, 02:53 PM
rhodyguy Cleaning the engine compartment is quick and easy ... Aug 24 2019, 10:03 PM
Gatornapper The PO responded to my query and insists that he d... Aug 25 2019, 11:35 AM
Superhawk996
The PO responded to my query and insists that he ... Aug 25 2019, 11:45 AM
Gatornapper SH -
Totally get it. But, mine does only have 60... Aug 25 2019, 11:54 AM
Superhawk996
SH -
Totally get it. But, mine does only have 6... Aug 25 2019, 01:32 PM
Gatornapper SH -
Only makes sense, I agree - especially since... Aug 25 2019, 07:24 PM
Superhawk996
SH -
Only makes sense, I agree - especially sinc... Aug 26 2019, 06:04 AM
Gatornapper I have the full and true story on the FI-Weber con... Aug 26 2019, 07:11 AM
Gatornapper Perfect. I have the scope - will do this for sure... Aug 26 2019, 09:40 AM
Al Meredith Here in the South (Atlanta) I have built several H... Aug 25 2019, 12:07 PM
Gatornapper Al - totally understand - flaps ON THE WAY from an... Aug 25 2019, 01:17 PM
ClayPerrine
Here in the South (Atlanta) I have built several ... Aug 25 2019, 08:07 PM
Gatornapper Totally remember all cars were good for 100k mis. ... Aug 26 2019, 07:20 AM
wndsrfr
Totally remember all cars were good for 100k mis.... Aug 26 2019, 08:09 AM
Gatornapper John -
Like here:
https://aapistons.com/collecti... Aug 26 2019, 09:18 AM
Gatornapper John -
Does the bore for the 96mm pistons give yo... Aug 26 2019, 09:26 AM
Gatornapper Chris -
THANK YOU FOR THIS POST! VERY educat... Aug 26 2019, 07:07 PM
rhodyguy How was the vane on dr side positioned? Aug 26 2019, 02:37 PM
ChrisFoley No, I have the engine out of the car. I wouldn... Aug 26 2019, 08:30 PM
Gatornapper Chris -
Thank you. I've never seen your oil ... Aug 27 2019, 05:41 AM
ChrisFoley
Chris -
Thank you. I've never seen your oil... Aug 27 2019, 07:24 AM
Gatornapper Thanks, Chris.
"Be careful with synthetic oi... Aug 27 2019, 07:23 PM
ChrisFoley
"High oil pressure = no oil moving in t... Aug 28 2019, 05:18 AM
Gatornapper Cool! Great design...
The stock pressure re... Aug 28 2019, 09:40 AM
Superhawk996 I’ll defer to Chris on this for racing applicati... Aug 28 2019, 10:38 AM
ChrisFoley
Keep in mind, hot oil is usually not high pressur... Aug 28 2019, 11:11 AM
Superhawk996 Just want to be clear my intent isn’t to start a... Aug 28 2019, 12:52 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 11:25 AM |
