> Found the fuel filter....
advman89
post Jul 22 2019, 09:11 PM
Does this look correct? This is on the passenger side, in front of the rear tire. I had been looking for something like the Mahle canister.
(Sorry for the bad pic!)
Pelican sent me a Mahle filter...round, not square...can I use this?
Part# 311-133-511-D-M67
Mahle KL 11 OF
1971 Car, 2.0 with some various bits from a 1975...just trying to sort what's what.
VaccaRabite
post Aug 26 2019, 10:10 AM
En Garde!
Yes, but not in the engine bay!
It has to be low - lower then the gas tank or there isnt any fuel gravity fed to the pump. Its own issue.
most people relocate them to the front trunk under the gas tank, or under the front trunk near the steering rack.
The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up.
Zach
post Aug 26 2019, 11:55 AM
Resident German
QUOTE(VaccaRabite @ Aug 26 2019, 09:10 AM) *
One thing to consider when relocating the fuel pump to the front:
With the old stock setup the plastic lines through the center tunnel were LOW pressure with the pump sucking fuel through them and the filter, then building pressure in only a short run of fuel lines from just under the engine shelf.
If you relocate the pump (and filter) to the front, you are now running HIGH pressure through 40 year old plastic fuel lines that were never designed to handle such pressure.
When i did my conversion, i had to mount the pump under the tank (993 pumps aren't good at sucking) so i replaced the plastic lines with the stainless steel fuel lines through the center tunnel.
advman89   Found the fuel filter....   Jul 22 2019, 09:11 PM
JawjaPorsche   The original location of the fuel pump and filter ...   Jul 23 2019, 04:32 AM
advman89   Thank you... Guess that full fuel line hose repla...   Jul 23 2019, 08:27 PM
advman89   Ugh. I'm hoping someone can help! Where...   Aug 25 2019, 10:31 AM
dabird   Take the plate off that's covering the steerin...   Aug 25 2019, 10:51 AM
SirAndy   On a '71 the fuel pump is under the pass. side...   Aug 25 2019, 11:06 AM
advman89   Thanks everyone. This car is so much the flipside ...   Aug 26 2019, 09:45 AM
VaccaRabite   Yes, but not in the engine bay! It has to be ...   Aug 26 2019, 10:10 AM
SirAndy   The factory changed the location in 75-76 cars and...   Aug 26 2019, 11:55 AM
ClayPerrine   [quote name='VaccaRabite' post='2741743' date='Au...   Aug 26 2019, 12:03 PM
Jamie   The factory changed the location in 75-76 cars an...   Aug 26 2019, 05:25 PM
advman89   Plan is to replace all the lines...tank to injecto...   Aug 26 2019, 12:30 PM
advman89   Found. It's under the car, by the rear passeng...   Aug 26 2019, 06:21 PM
tmc914   In the front near the front axle there is a panel ...   Aug 26 2019, 09:16 PM
914werke   What material did the factory use for fuel lines ...   Aug 27 2019, 10:00 AM
VaccaRabite   What material did the factory use for fuel lines...   Aug 27 2019, 11:10 AM
ClayPerrine   The lines in my BMW '75 2002 were the same e...   Aug 29 2019, 08:51 PM
914werke   Nope. I dont know what went on with your car Zach ...   Aug 27 2019, 12:35 PM
- Lo-Fi Version Time is now: 15th April 2026 - 11:41 PM
