| advman89 |
Jul 22 2019, 09:11 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest
Does this look correct? This is on the passenger side, in front of the rear tire. I had been looking for something like the Mahle canister.
(Sorry for the bad pic!) Pelican sent me a Mahle filter...round, not square...can I use this? Part# 311-133-511-D-M67 Mahle KL 11 OF 1971 Car, 2.0 with some various bits from a 1975...just trying to sort what's what. |
| VaccaRabite |
Aug 26 2019, 10:10 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Yes, but not in the engine bay!
It has to be low - lower then the gas tank or there isnt any fuel gravity fed to the pump. Its own issue. most people relocate them to the front trunk under the gas tank, or under the front trunk near the steering rack. The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. Zach |
| SirAndy |
Aug 26 2019, 11:55 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,473 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. One thing to consider when relocating the fuel pump to the front: With the old stock setup the plastic lines through the center tunnel were LOW pressure with the pump sucking fuel through them and the filter, then building pressure in only a short run of fuel lines from just under the engine shelf. If you relocate the pump (and filter) to the front, you are now running HIGH pressure through 40 year old plastic fuel lines that were never designed to handle such pressure. When i did my conversion, i had to mount the pump under the tank (993 pumps aren't good at sucking) so i replaced the plastic lines with the stainless steel fuel lines through the center tunnel. (IMG:style_emoticons/default/shades.gif) |
| ClayPerrine |
Aug 26 2019, 12:03 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The factory changed the location in 75-76 cars and had an opening low on the pass side of the front trunk under the tank, and many people re-create that with earlier cars. Its a much better set up. One thing to consider when relocating the fuel pump to the front: With the old stock setup the plastic lines through the center tunnel were LOW pressure with the pump sucking fuel through them and the filter, then building pressure in only a short run of fuel lines from just under the engine shelf. If you relocate the pump (and filter) to the front, you are now running HIGH pressure through 40 year old plastic fuel lines that were never designed to handle such pressure. When i did my conversion, i had to mount the pump under the tank (993 pumps aren't good at sucking) so i replaced the plastic lines with the stainless steel fuel lines through the center tunnel. (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/agree.gif) Replace the plastic lines. Don't end up standing on the side of the road watching your 914 burn. Betty and I watched her car burn. It was heartbreaking, and almost cost us our marriage. Took a few years before I could face rebuilding the car. I would even recommend replacing them if you keep the fuel pump in the stock location. I did that to our factory six right after we got it. It is the only non-reversible thing we have done to that car. And it was done purely for safety. |
advman89 Found the fuel filter.... Jul 22 2019, 09:11 PM
JawjaPorsche The original location of the fuel pump and filter ... Jul 23 2019, 04:32 AM
advman89 Thank you...
Guess that full fuel line hose repla... Jul 23 2019, 08:27 PM
advman89 Ugh.
I'm hoping someone can help!
Where... Aug 25 2019, 10:31 AM
dabird Take the plate off that's covering the steerin... Aug 25 2019, 10:51 AM
SirAndy On a '71 the fuel pump is under the pass. side... Aug 25 2019, 11:06 AM
advman89 Thanks everyone. This car is so much the flipside ... Aug 26 2019, 09:45 AM
Jamie
The factory changed the location in 75-76 cars an... Aug 26 2019, 05:25 PM
advman89 Plan is to replace all the lines...tank to injecto... Aug 26 2019, 12:30 PM
advman89 Found. It's under the car, by the rear passeng... Aug 26 2019, 06:21 PM
tmc914 In the front near the front axle there is a panel ... Aug 26 2019, 09:16 PM
914werke What material did the factory use for fuel lines ... Aug 27 2019, 10:00 AM
VaccaRabite
What material did the factory use for fuel lines... Aug 27 2019, 11:10 AM
ClayPerrine
The lines in my BMW '75 2002 were the same e... Aug 29 2019, 08:51 PM
914werke Nope. I dont know what went on with your car Zach ... Aug 27 2019, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 11:43 PM |
