> 1975 914 1.8L-Going Forward In Reverse, Forward in Reverse
ballsyfacts914
post Aug 28 2019, 08:25 PM
So...just got my 914, as in today and my first spin was great, all my dreams came true. Then I couldn't get it into 1st gear. After some research, thought I found a solution but then I couldn't get it out of the garage as reverse made it go forward, could get it into 1st though so got that going for me. I am a novice and I expected some issues but dang! Any suggestions?
Thanks to all in advance!
Mblizzard
post Aug 29 2019, 01:11 PM
What year is your car?
Can you get into reverse when engine stopped and then start the car and get it to go in reverse?
ballsyfacts914
post Aug 29 2019, 01:47 PM
QUOTE(Mblizzard @ Aug 29 2019, 02:11 PM) *
1975 rebuilt 1.8L. When car is off I can put into reverse and cycle through all the gears. If I leave in reverse and start the car it goes forward.
Mblizzard
post Aug 29 2019, 01:59 PM
QUOTE(ballsyfacts914 @ Aug 29 2019, 11:47 AM) *
Ok not being smart here. But if you start it and it goes forward after putting in reverse, you are not getting it into reverse when stopped.
That means something is blocking the shifter from operating correctly. Start with a little light reading!
Attached File  914_Shifting_Improvements.pdf ( 166.33k ) Number of downloads: 102
ballsyfacts914
post Aug 29 2019, 02:58 PM
QUOTE(Mblizzard @ Aug 29 2019, 02:59 PM) *
Perfect, thank you
ballsyfacts914   1975 914 1.8L-Going Forward In Reverse   Aug 28 2019, 08:25 PM
SirAndy   :wttc: Not trying to be condescending but are yo...   Aug 28 2019, 08:35 PM
rhodyguy   You have to push against a spring loaded plate for...   Aug 28 2019, 08:54 PM
ballsyfacts914   I appreciate all the responses, I can shift throug...   Aug 29 2019, 12:52 PM
wes   This is a jok right?   Aug 28 2019, 10:04 PM
ballsyfacts914   Nope, wish it wasn't.   Aug 29 2019, 12:48 PM
Mblizzard   If the shift components are worn it can be a Ze...   Aug 29 2019, 06:53 AM
jcd914   :wttc: Check the shift linkage bushing, they can...   Aug 29 2019, 08:39 AM
ballsyfacts914   Oh yeah, I will say I was initially confused but I...   Aug 29 2019, 12:47 PM
Mblizzard   What year is your car? Can you get into reverse w...   Aug 29 2019, 01:11 PM
ballsyfacts914   What year is your car? Can you get into reverse ...   Aug 29 2019, 01:47 PM
Mblizzard   What year is your car? Can you get into reverse...   Aug 29 2019, 01:59 PM
ballsyfacts914   [quote name='ballsyfacts914' post='2742553' date=...   Aug 29 2019, 02:58 PM
Spoke   ... If I leave in reverse and start the car it go...   Aug 29 2019, 02:11 PM
ballsyfacts914   ... If I leave in reverse and start the car it g...   Aug 29 2019, 03:06 PM
rhodyguy   You need to inspect the whole linkage. Sorta ok on...   Aug 29 2019, 03:28 PM
fiacra   So...just got my 914, as in today and my first sp...   Aug 29 2019, 03:35 PM
ballsyfacts914   So...just got my 914, as in today and my first s...   Aug 29 2019, 05:13 PM
Krieger   Check the amount of play in the clutch pedal. If ...   Aug 29 2019, 05:34 PM
SirAndy   Check the cone setscrew at the shift coupler right...   Aug 29 2019, 08:04 PM
ballsyfacts914   Check the cone setscrew at the shift coupler righ...   Aug 29 2019, 08:37 PM
Superhawk996   Adjustment of all shift linkage and having all the...   Aug 30 2019, 07:03 AM
ballsyfacts914   OK, checked the set screw behind the firewall and ...   Sep 1 2019, 12:46 PM
DickSteinkamp   OK, checked the set screw behind the firewall and...   Sep 1 2019, 01:10 PM
ballsyfacts914   OK, checked the set screw behind the firewall an...   Sep 1 2019, 01:47 PM
Superhawk996   Also under that big plastic cover there is another...   Sep 1 2019, 01:13 PM
PanelBilly   I’ve had good luck adjusting the connection wher...   Sep 1 2019, 01:22 PM
ballsyfacts914   I’ve had good luck adjusting the connection whe...   Sep 1 2019, 01:46 PM
rhodyguy   To be clear. When running and you push the lever H...   Sep 2 2019, 10:59 AM
ballsyfacts914   To be clear. When running and you push the lever ...   Sep 2 2019, 11:09 AM
rhodyguy   What have you taken off and put back on? Other tha...   Sep 2 2019, 11:20 AM
ballsyfacts914   What have you taken off and put back on? Other th...   Sep 2 2019, 11:55 AM
ballsyfacts914   Also, for the front linkage, the one I can access ...   Sep 2 2019, 01:54 PM
rhodyguy   "assume" or you've tried? I wouldn...   Sep 2 2019, 03:26 PM
ballsyfacts914   "assume" or you've tried? I wouldn...   Sep 2 2019, 04:15 PM
rhodyguy   No.   Sep 2 2019, 05:51 PM
ballsyfacts914   No. Fair enough, thanks   Sep 2 2019, 08:44 PM
ballsyfacts914   I wanted to thank everyone for providing tips and ...   Sep 8 2019, 12:22 PM
fiacra   I wanted to thank everyone for providing tips and...   Sep 8 2019, 01:44 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:25 PM
