| advman89 |
Jul 22 2019, 09:11 PM
Member ![]() ![]() Group: Members Posts: 120 Joined: 8-July 19 From: Chicago, IL Member No.: 23,286 Region Association: Upper MidWest
Does this look correct? This is on the passenger side, in front of the rear tire. I had been looking for something like the Mahle canister.
(Sorry for the bad pic!) Pelican sent me a Mahle filter...round, not square...can I use this? Part# 311-133-511-D-M67 Mahle KL 11 OF 1971 Car, 2.0 with some various bits from a 1975...just trying to sort what's what. |
| 914werke |
Aug 27 2019, 10:00 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,624 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
What material did the factory use for fuel lines through the tunnel when fuel pump was relocated to the front? Not exactly sure. It has been discussed before & you may be able to find it with a search of the board but the two types of lines are easily distinguished. The early lines are clear/opaque while the late Hi-pres lines are Black. |
| VaccaRabite |
Aug 27 2019, 11:10 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,845 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
What material did the factory use for fuel lines through the tunnel when fuel pump was relocated to the front? Not exactly sure. It has been discussed before & you may be able to find it with a search of the board but the two types of lines are easily distinguished. The early lines are clear/opaque while the late Hi-pres lines are Black. Pretty sure they used the same center tunnel lines regardless of where the fuel pump was. My 76 had the clear/opaque lines and the factory mounted front pump. That said, I pulled those lines out and replaced them with SS from Chris before i ever fired the motor on my car. The lines in my BMW '75 2002 were the same exact material. I'm replacing them as well. the theory in the BMW community is that in the event of a fire, the plastic would melt closed and keep new fuel from feeding a fire in the cabin. Ha ha ha, good one Potsy. Going to metal lines in the '02 as well and not routing them through the cabin. The plastic tunnel lines were never designed for ethanol. Everyone should pull them and replace them. I have a picture of a plastic fuel filter that was on my car when it had carbs, and the plastic is sagging due to ethanol. Scary. Zach |
| ClayPerrine |
Aug 29 2019, 08:51 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
The lines in my BMW '75 2002 were the same exact material. I'm replacing them as well. the theory in the BMW community is that in the event of a fire, the plastic would melt closed and keep new fuel from feeding a fire in the cabin. Ha ha ha, good one Potsy. Going to metal lines in the '02 as well and not routing them through the cabin. Having gone through an engine fire, I can tell you for sure that the plastic lines won't melt closed, they just melt holes in the lines so the gasoline can feed the fire! |
advman89 Found the fuel filter.... Jul 22 2019, 09:11 PM
JawjaPorsche The original location of the fuel pump and filter ... Jul 23 2019, 04:32 AM
advman89 Thank you...
Guess that full fuel line hose repla... Jul 23 2019, 08:27 PM
advman89 Ugh.
I'm hoping someone can help!
Where... Aug 25 2019, 10:31 AM
dabird Take the plate off that's covering the steerin... Aug 25 2019, 10:51 AM
SirAndy On a '71 the fuel pump is under the pass. side... Aug 25 2019, 11:06 AM
advman89 Thanks everyone. This car is so much the flipside ... Aug 26 2019, 09:45 AM
VaccaRabite Yes, but not in the engine bay!
It has to be ... Aug 26 2019, 10:10 AM
SirAndy The factory changed the location in 75-76 cars and... Aug 26 2019, 11:55 AM
ClayPerrine
[quote name='VaccaRabite' post='2741743' date='Au... Aug 26 2019, 12:03 PM
Jamie
The factory changed the location in 75-76 cars an... Aug 26 2019, 05:25 PM
advman89 Plan is to replace all the lines...tank to injecto... Aug 26 2019, 12:30 PM
advman89 Found. It's under the car, by the rear passeng... Aug 26 2019, 06:21 PM
tmc914 In the front near the front axle there is a panel ... Aug 26 2019, 09:16 PM
914werke Nope. I dont know what went on with your car Zach ... Aug 27 2019, 12:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 10:07 PM |
