> 1975 914 1.8L-Going Forward In Reverse, Forward in Reverse
ballsyfacts914
post Aug 28 2019, 08:25 PM
So...just got my 914, as in today and my first spin was great, all my dreams came true. Then I couldn't get it into 1st gear. After some research, thought I found a solution but then I couldn't get it out of the garage as reverse made it go forward, could get it into 1st though so got that going for me. I am a novice and I expected some issues but dang! Any suggestions?
Thanks to all in advance!
rhodyguy
post Sep 2 2019, 03:26 PM
"assume" or you've tried? I wouldn't sweat it too much til you put the the new bushings in.
ballsyfacts914   1975 914 1.8L-Going Forward In Reverse   Aug 28 2019, 08:25 PM
SirAndy   :wttc: Not trying to be condescending but are yo...   Aug 28 2019, 08:35 PM
rhodyguy   You have to push against a spring loaded plate for...   Aug 28 2019, 08:54 PM
ballsyfacts914   I appreciate all the responses, I can shift throug...   Aug 29 2019, 12:52 PM
wes   This is a jok right?   Aug 28 2019, 10:04 PM
ballsyfacts914   Nope, wish it wasn't.   Aug 29 2019, 12:48 PM
Mblizzard   If the shift components are worn it can be a Ze...   Aug 29 2019, 06:53 AM
jcd914   :wttc: Check the shift linkage bushing, they can...   Aug 29 2019, 08:39 AM
ballsyfacts914   Oh yeah, I will say I was initially confused but I...   Aug 29 2019, 12:47 PM
Mblizzard   What year is your car? Can you get into reverse w...   Aug 29 2019, 01:11 PM
ballsyfacts914   What year is your car? Can you get into reverse ...   Aug 29 2019, 01:47 PM
Mblizzard   What year is your car? Can you get into reverse...   Aug 29 2019, 01:59 PM
ballsyfacts914   [quote name='ballsyfacts914' post='2742553' date=...   Aug 29 2019, 02:58 PM
Spoke   ... If I leave in reverse and start the car it go...   Aug 29 2019, 02:11 PM
ballsyfacts914   ... If I leave in reverse and start the car it g...   Aug 29 2019, 03:06 PM
rhodyguy   You need to inspect the whole linkage. Sorta ok on...   Aug 29 2019, 03:28 PM
fiacra   So...just got my 914, as in today and my first sp...   Aug 29 2019, 03:35 PM
ballsyfacts914   So...just got my 914, as in today and my first s...   Aug 29 2019, 05:13 PM
Krieger   Check the amount of play in the clutch pedal. If ...   Aug 29 2019, 05:34 PM
SirAndy   Check the cone setscrew at the shift coupler right...   Aug 29 2019, 08:04 PM
ballsyfacts914   Check the cone setscrew at the shift coupler righ...   Aug 29 2019, 08:37 PM
Superhawk996   Adjustment of all shift linkage and having all the...   Aug 30 2019, 07:03 AM
ballsyfacts914   OK, checked the set screw behind the firewall and ...   Sep 1 2019, 12:46 PM
DickSteinkamp   OK, checked the set screw behind the firewall and...   Sep 1 2019, 01:10 PM
ballsyfacts914   OK, checked the set screw behind the firewall an...   Sep 1 2019, 01:47 PM
Superhawk996   Also under that big plastic cover there is another...   Sep 1 2019, 01:13 PM
PanelBilly   I’ve had good luck adjusting the connection wher...   Sep 1 2019, 01:22 PM
ballsyfacts914   I’ve had good luck adjusting the connection whe...   Sep 1 2019, 01:46 PM
rhodyguy   To be clear. When running and you push the lever H...   Sep 2 2019, 10:59 AM
ballsyfacts914   To be clear. When running and you push the lever ...   Sep 2 2019, 11:09 AM
rhodyguy   What have you taken off and put back on? Other tha...   Sep 2 2019, 11:20 AM
ballsyfacts914   What have you taken off and put back on? Other th...   Sep 2 2019, 11:55 AM
ballsyfacts914   Also, for the front linkage, the one I can access ...   Sep 2 2019, 01:54 PM
rhodyguy   "assume" or you've tried? I wouldn...   Sep 2 2019, 03:26 PM
ballsyfacts914   "assume" or you've tried? I wouldn...   Sep 2 2019, 04:15 PM
rhodyguy   No.   Sep 2 2019, 05:51 PM
ballsyfacts914   No. Fair enough, thanks   Sep 2 2019, 08:44 PM
ballsyfacts914   I wanted to thank everyone for providing tips and ...   Sep 8 2019, 12:22 PM
fiacra   I wanted to thank everyone for providing tips and...   Sep 8 2019, 01:44 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:21 PM
