Grinding as I shift to Reverse |
malcolm2 |
Sep 3 2019, 03:51 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
The forum answered this not too long ago. But let's see if I have another issue.
So the answer back in April seemed to be that the cable was stretching when HOT. I adjusted and the grind went away. But a month later the TOB crapped out. So, New TOB, Clutch, Pressure Plate, Seals, Cable, etc.... and today I drove home for lunch. Maybe 90* air temp, 230 Oil temp, 30 psi Oil pressure, 325 CHT. As I tried to back out of the driveway.... GRINDDDD. Every time. So I started the car with the clutch in and in reverse. Backed out and drove to work. 4 hours of cooling in the parking lot and NO GRIND for backing out of my parking spot. But similar system temps on the way home. Pulled in the garage and GRINDDD again as I test Reverse before I shut down. You think I am dealing a heat related stretch again on this new cable? Plan is to tighten it up a thread or two after it cools. Did I miss anything? |
malcolm2 |
Sep 3 2019, 08:09 PM
Worked like a champ. 2 full turns on the clutch cable nut and shifting into R was much smoother, 1st too. still have pedal play. Of course I could not simulate the 90* air temp and did not take it to the interstate, but there is tomorrow for a full test.
I guess you just get used to the way thing work until it gets way out of adjustment. Truthfully I would not want to own this car if I had to take it to the shop for every little hiccup of which there are many. And if it had not needed EVERYTHING to be replaced, I probably would be in much worse shape as a wrencher of this car. Clark |
worn |
Sep 3 2019, 09:19 PM
can't remember Group: Members Posts: 3,164 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Worked like a champ. 2 full turns on the clutch cable nut and shifting into R was much smoother, 1st too. still have pedal play. Of course I could not simulate the 90* air temp and did not take it to the interstate, but there is tomorrow for a full test. I guess you just get used to the way thing work until it gets way out of adjustment. Truthfully I would not want to own this car if I had to take it to the shop for every little hiccup of which there are many. And if it had not needed EVERYTHING to be replaced, I probably would be in much worse shape as a wrencher of this car. Clark You are not alone. Reverse seems to be the warning lamp for clutch problems. Spent much of today messing with transmission controls, clutch cable and shift linkage, today. Ended up turning a bronze bushing for the transmission console. Also reconfigured my shift bar. A lot of my troubles seem to be getting enough clutch travel while maintaining pedal free play. Drove a few blocks and everything seemeed to shift perfect. But i have heard that story before. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:04 AM |
