Grinding as I shift to Reverse |
malcolm2 |
Sep 3 2019, 03:51 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
The forum answered this not too long ago. But let's see if I have another issue.
So the answer back in April seemed to be that the cable was stretching when HOT. I adjusted and the grind went away. But a month later the TOB crapped out. So, New TOB, Clutch, Pressure Plate, Seals, Cable, etc.... and today I drove home for lunch. Maybe 90* air temp, 230 Oil temp, 30 psi Oil pressure, 325 CHT. As I tried to back out of the driveway.... GRINDDDD. Every time. So I started the car with the clutch in and in reverse. Backed out and drove to work. 4 hours of cooling in the parking lot and NO GRIND for backing out of my parking spot. But similar system temps on the way home. Pulled in the garage and GRINDDD again as I test Reverse before I shut down. You think I am dealing a heat related stretch again on this new cable? Plan is to tighten it up a thread or two after it cools. Did I miss anything? |
ndfrigi |
Sep 3 2019, 11:06 PM
Advanced Member Group: Members Posts: 2,933 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
maybe a silly question, do you have 2 nuts at the adjustment end to use as locking nut? If only 1 nut on the adjustment end cable, probably it loosens little by little. And also check your clutch tube from firewall and along the tunnel.
malcolm2 |
Sep 4 2019, 08:06 AM
maybe a silly question, do you have 2 nuts at the adjustment end to use as locking nut? If only 1 nut on the adjustment end cable, probably it loosens little by little. And also check your clutch tube from firewall and along the tunnel. Yes, 2 nuts. I used 2 nylocs. I usually count the threads showing and take a picture so I know. This time I did it all without jacking up the car, so I did not have room to get a picture. But I am changing the oil this weekend, before the Banner Elk drive, so I will document the nut location then. My PO fixed the clutch tube with a U-Bolt. He cut a bunch of door knob holes in the top of the tunnel trying to find the break and where to drill for the U-Bolt. Seems to be holding up well. I'll take a look at that this weekend too. With all those holes it is easy to check for tube movement by yourself. (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:37 AM |
