Thoughts on putting a Chevy/GMC late model 4.3L or 3.6L engine in 914, 4 |
9144me2enjoy |
Sep 3 2019, 11:32 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
What are your thoughts or problems to be expected on either putting a Aluminum 2014 Chevy 4.3L V6 LV3 engine (285hp/305 lb Torque) in a 914 using a 901 Transmission or a 2017 Aluminum GM 3.6L V6 LGZ engine (308hp/275 lb torque) in a 914 using a 901 transmission? I’ve checked with Kennedy they have the correct adapter kit for the engines to the 901 transmission. Both engines weigh 340-400 lbs. each. What draws my attention to these engines is the late model technology, weight, size, hp, torque.....I know the stock new E92 ECU would probably be a bear. I realize the 901 trans would have to have the upper gears addressed and beefier axles and cooling would have to be addressed. Thanks
Chi-town |
Sep 4 2019, 09:38 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Aluminum LS is about the same weight as a -6 with a center of gravity just slightly higher which gets offset by the weight of the radiator and coolant lines filled with coolant at the lowest points of the car.
Technically a -6 oil tank raises the COG also (IMG:style_emoticons/default/laugh.gif) Ad to that a much better shifting and stronger Boxster S trans which makes a 901 look like the stone ages (which it is). As for wiring, I wouldn't consider having to connect Batt power, Switched Ignition power, and ground a "mess " or a "nightmare". The availability of standalone harnesses for cheap have eliminated this issue. Old school SBC, 12v switched for the HEI and Alt. Generator light hook up And a ground. Done There's a reason there's so many V8 swaps out there and why Renegade is booked solid. It was originally my second option after the suby |
Lo-Fi Version | Time is now: 7th June 2024 - 09:56 AM |
