Thoughts on putting a Chevy/GMC late model 4.3L or 3.6L engine in 914, 4 |
9144me2enjoy |
Sep 3 2019, 11:32 AM
Member Group: Members Posts: 310 Joined: 19-June 18 From: Oregon Member No.: 22,240 Region Association: Pacific Northwest |
What are your thoughts or problems to be expected on either putting a Aluminum 2014 Chevy 4.3L V6 LV3 engine (285hp/305 lb Torque) in a 914 using a 901 Transmission or a 2017 Aluminum GM 3.6L V6 LGZ engine (308hp/275 lb torque) in a 914 using a 901 transmission? I’ve checked with Kennedy they have the correct adapter kit for the engines to the 901 transmission. Both engines weigh 340-400 lbs. each. What draws my attention to these engines is the late model technology, weight, size, hp, torque.....I know the stock new E92 ECU would probably be a bear. I realize the 901 trans would have to have the upper gears addressed and beefier axles and cooling would have to be addressed. Thanks
Crisperez8941 |
Sep 5 2019, 05:23 PM
Newbie Group: Members Posts: 7 Joined: 21-August 19 From: Commerce CA Member No.: 23,393 Region Association: None |
What are your thoughts or problems to be expected on either putting a Aluminum 2014 Chevy 4.3L V6 LV3 engine (285hp/305 lb Torque) in a 914 using a 901 Transmission or a 2017 Aluminum GM 3.6L V6 LGZ engine (308hp/275 lb torque) in a 914 using a 901 transmission? I’ve checked with Kennedy they have the correct adapter kit for the engines to the 901 transmission. Both engines weigh 340-400 lbs. each. What draws my attention to these engines is the late model technology, weight, size, hp, torque.....I know the stock new E92 ECU would probably be a bear. I realize the 901 trans would have to have the upper gears addressed and beefier axles and cooling would have to be addressed. Thanks im currently in the process of doing that same swap. dump the 901 transmission and get yourself the boxster s tranny. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:13 AM |
