MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
...when going slow AND turning left. Otherwise not at all. Clunks, 3 or 4, from the driver’s side, rear. Sounds as if something like the heat exchanger was resting on the trailer arm and then bounced when going over a bump. I KNOW this is not the sound and that it’s not possible. Just describing!
So, is there something up with my rear wheel bearing?i just changed out the CV joint bearings! Could it be one is already faulty?! Interested in your opinions. Danke! M.i.M. |
dlee6204 |
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 ![]() |
My vote is on a missing C Clip. Can you replicate the noise by moving the axle in and out? It could also be bad CVs.
MikeInMunich |
My vote is on a missing C Clip. Can you replicate the noise by moving the axle in and out? It could also be bad CVs. Thanks for your reply! The bolts are not loose. When the bearings were changed a few weeks ago there was no original C clip available. One was used, but not one that was specifically for this application. Assuming those clips failed, do ya reckon I am now dealing with damaged bearings and will need to replace them again? Also, how much play in the axle should there be, in and out? I have about a full inch! M.i.M. |
Lo-Fi Version | Time is now: 1st August 2025 - 02:37 PM |
