MikeInMunich |
Member ![]() ![]() Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None ![]() |
...when going slow AND turning left. Otherwise not at all. Clunks, 3 or 4, from the driver’s side, rear. Sounds as if something like the heat exchanger was resting on the trailer arm and then bounced when going over a bump. I KNOW this is not the sound and that it’s not possible. Just describing!
So, is there something up with my rear wheel bearing?i just changed out the CV joint bearings! Could it be one is already faulty?! Interested in your opinions. Danke! M.i.M. |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,829 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
Good Question, "Also, how much play in the axle should there be, in and out? I have about a full inch! "
When my 914 is in the shop, the mechanic will grab the shaft and feel the amoun of lateral play; always wondered how much there should be. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 02:37 PM |
