Something Evil Part II, Starting Over |
Mblizzard |
Apr 17 2019, 08:17 AM
Well I have been delayed with life and too many things going on. But after purchasing a lot of parts, it is time to start the process.
Up front big thanks to Charles and Nicole at the Type 4 Store for putting up with so many questions. Thanks to Len Hoffman for waiting on me for so long on the heads. Also to Jake Raby for his Type 4 build CD and while not giving build advice but pointing me in the right direction on a number of issues. I am afraid to look at all of the other vendor receipts as I might start to add it all up $$$$ but I will compile a list of all the vendors and add photos. So the basics. Going for a 2.6 L FI with Microsquirt. Looking to hit 9.5:1 compression. 102 mm Nickies with Custom 102mm Dished JE Pistons for 78mm stroke and 22mm pins. 78 mm crank - New this time! H-beam Rods 5.325 with Type 1 Rod Journals LE-200 heads - Valve sizes: 44mm x 38mm by Manley, intake ports flow 200CFM @ .500” valve lift, and ceramic coated. 911 swivel foot valve adjusters SPEC Clutch Kit - Stage 1 Lightened flywheel Type 4 Store Cam Part# 9500 with Parkerized Lifters and Modified Cam Gear, chromoly pushrods Intake Valve Lift: .500 Duration: 284 Duration@ .050": 250 Exhaust Valve Lift: .500 Duration: 300 Duration@ .050": 270 Mahle bearings throughout 315cc/min Fuel Injector: Bosch 0280150945 48 mm CB Performance intakes. Dual throttle bodies with CSP linkage Modified 30mm Oil Pump Racewear Case thru-Stud Kit and Head Stud Kit Tangerine Racing Remote Oil Cooler Kit Planning on Tangerine Racing 1 1/2" Street System: - High Temp coated header with EVO II Silencer Case and all the parts are going to shop Friday for opening up to fit the 102s and balancing of all parts. Goal is to be done by Okteenerfest! May have potential to be evil? Thoughts suggestions? |
Mblizzard |
Sep 6 2019, 07:13 AM
No time for pictures but it is in! Will skip out from work today and get it wired in and go for start on Sunday. |
malcolm2 |
Sep 6 2019, 07:16 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
No time for pictures but it is in! Will skip out from work today and get it wired in and go for start on Sunday. Do you have a busy Saturday planned? I hope it is not a waste of our time... (IMG:style_emoticons/default/barf.gif) |
Mblizzard |
Sep 6 2019, 07:26 AM
No time for pictures but it is in! Will skip out from work today and get it wired in and go for start on Sunday. Do you have a busy Saturday planned? I hope it is not a waste of our time... (IMG:style_emoticons/default/barf.gif) I am considering not going but my wife says I cant be a baby so I guess I am going. Got extra tickets if you are in the need of some pain! |
malcolm2 |
Sep 6 2019, 07:56 AM
I am considering not going but my wife says I cant be a baby so I guess I am going. Got extra tickets if you are in the need of some pain! Can't say I am looking forward to it myself. But I plan on numbing the pain starting at noon. (IMG:style_emoticons/default/beer3.gif) Maybe I'll have a second to swing by on our way home Sunday. Course, if you've seen 1 TIV engine you have seen them all. (IMG:style_emoticons/default/piratenanner.gif) |
Mblizzard |
Sep 6 2019, 08:03 AM
I am considering not going but my wife says I cant be a baby so I guess I am going. Got extra tickets if you are in the need of some pain! Can't say I am looking forward to it myself. But I plan on numbing the pain starting at noon. (IMG:style_emoticons/default/beer3.gif) Maybe I'll have a second to swing by on our way home Sunday. Course, if you've seen 1 TIV engine you have seen them all. (IMG:style_emoticons/default/piratenanner.gif) True! |
Lo-Fi Version | Time is now: 7th June 2024 - 10:33 AM |
