> Head Bolt Removal and Installation Tips Needed, Teardown
cassmcentee
post Sep 6 2019, 11:37 AM
Starting the disassembly of my 72 2.0
Some head bolts stayed with the Case
Others came out with the head
How do you guys/gals deal with removal so as not to SCAR the bolts?
IronHillRestorations
post Sep 6 2019, 12:25 PM
I. I. R. C.
If you are pulling all the head studs, first put some Seafoam Deep Creep penetrating oil on them, and if you have time let them sit for a day, and tapping with a brass or plastic hammer will help the oil work. Most of the time you can put two nuts on the top threads, tighten them against each other and use that to back them out. If they are rusty (like yours) this can cause them to break, so I'd carefully add some heat with a MAP or propane torch.
cassmcentee
post Sep 6 2019, 12:50 PM
QUOTE(IronHillRestorations @ Sep 6 2019, 01:25 PM) *
Cool, Thank you Perry, I have plenty of time!
What about the ones trapped on the head?
Add two nuts to the bottom threads to counter the top nut???
- Lo-Fi Version Time is now: 26th November 2026 - 12:09 AM
