| BENBRO02 |
Sep 7 2019, 09:58 AM
Member ![]() ![]() Group: Members Posts: 485 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region
Near as I can tell my 1975 had all early front suspension on it with late calipers. Washers were added in between the spindles and the calipers, and spacers were added between the rotors and wheels.
I had a shimmy at highway speed and want to correct the problem before heading to Okteenerfest. To correct the problem I bought the following from PMB: Late hard brakes lines Wheel bearings Late rotors Ball joint pins Late strut housings and spindles I already have late calipers so I plan on using them. I have 2 problems. I can't drive the pins into the ball joints (apparently I have early ball joints and didn't realize there was a difference). That's an easy fix but may not happen in time to make Okteenerfest. The second problem is that I can't fit the calipers. I was thinking that maybe I have some non 914 calipers so I bought some used late calipers from Bruce Stone (thanks Bruce). The calipers that Bruce sent are the same as what I had so I must have the correct calipers. The rotors are about an 1/8" off (to the outside) to work with the spindles and calipers. Is it possible I installed something incorrectly or are some of the parts still incorrect (in addition to the ball joints)? Attached thumbnail(s) |
| sixnotfour |
Sep 7 2019, 12:35 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,153 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
is the inner wheel bearing pressed all the way in to the seat ??
| bbrock |
Sep 7 2019, 12:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
| BENBRO02 |
Sep 7 2019, 03:39 PM
is the inner wheel bearing pressed all the way in to the seat ?? My thought also. Specifically, that the inner bearing race is pressed all the way in. Only thing I could think would hold the rotor out on the spindle. I used a special bearing race driver and it sure felt solidly seated and then I hit it a couple extra times to be sure. The rotor rubs on the dust shield too, telling me it's in as far as it should be? |
| BENBRO02 |
Sep 7 2019, 03:58 PM
is the inner wheel bearing pressed all the way in to the seat ?? My thought also. Specifically, that the inner bearing race is pressed all the way in. Only thing I could think would hold the rotor out on the spindle. I used a special bearing race driver and it sure felt solidly seated and then I hit it a couple extra times to be sure. The rotor rubs on the dust shield too, telling me it's in as far as it should be? Is the dust shield different early to late? Maybe that is stopping the rotor and bearing from seating properly? |
BENBRO02 Front Suspension and Brakes Sep 7 2019, 09:58 AM
mepstein You need the late ball joints. You can't mix a... Sep 7 2019, 10:36 AM
BENBRO02
You need the late ball joints. You can't mix ... Sep 7 2019, 10:44 AM
You need the late ball joints. You can't mix... Sep 7 2019, 10:50 AM
sixnotfour is the rotor hubcentric ? Sep 7 2019, 11:12 AM
BENBRO02
Yes Sep 7 2019, 11:57 AM
BENBRO02
[quote name='bbrock' post='2744996' date='Sep 7 ... Sep 7 2019, 06:26 PM
bdstone914 @BENBRO02
Yes early and late shield are differen... Sep 7 2019, 09:24 PM
BENBRO02
[b]@[url=http://www.914world.com/bbs2/index.php?s... Sep 8 2019, 07:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 10th March 2026 - 10:40 PM |
