Rocker Replacement - Screws for Rivets, Sheet metal screw size? |
FlacaProductions |
Sep 8 2019, 11:09 AM
Senior Member Group: Members Posts: 1,616 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks! |
North Coast Jim |
Sep 9 2019, 06:14 AM
Member Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top... Thanks! Use the rivets. I used pop rivets. The standard aluminum ones. Wrong color of course so I colored them with a magic marker. Looks good. |
Lo-Fi Version | Time is now: 10th June 2024 - 07:14 AM |
