| bbrock |
Sep 8 2019, 06:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Doing a bit of rehab on my front trunk lid in preparation for paint. One side of the A-frame member is stuck tight to the skin but the other side has lifted off about 3/32". I want to glue the lifted side down but don't know what adhesive would work best. 3M Panel Bonding Adhesive looks like it would be the ultimate but kind of expensive and probably overkill for this application. Any suggestions?
| burton73 |
Sep 10 2019, 09:59 AM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,970 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
Brent buddy,
You need to think this out. The heat of a day could make a big panel expand and if glued it may get a waive in the metal. I remember the space in there. I have done a few hoods in my time. Ck with more guys before you jump. You may be right but you may be wrong. See what George says or Eric Best, Bob B |
| Garland |
Sep 10 2019, 12:00 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,428 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
Brent buddy, You need to think this out. The heat of a day could make a big panel expand and if glued it may get a waive in the metal. I remember the space in there. I have done a few hoods in my time. Ck with more guys before you jump. You may be right but you may be wrong. See what George says or Eric Best, Bob B I agree with Bob, after reading his post, I would leave it alone. I did a close inspection of mine, looks like 45 years of temperature change, gravity, and stresses. Kind of like me! Here are a few shots, of mine, just reference. ![]() ![]() ![]() ![]() |
bbrock Gluing trunk/frunk skins to frame Sep 8 2019, 06:18 PM
raynekat I would think any kind of "2 part" epoxy... Sep 8 2019, 07:24 PM
worn I never knew they were bonded there. Thanks. Mak... Sep 8 2019, 08:42 PM
bbrock
I never knew they were bonded there. Thanks. Ma... Sep 8 2019, 10:14 PM
bbrock I think I'm going to pick up a tube of this 3M... Sep 10 2019, 08:41 AM
Garland Try this stuff it loves 914 Sep 10 2019, 09:05 AM
bbrock
I need to actually ... Sep 10 2019, 09:08 AM
SirAndy :welder: Sep 10 2019, 12:07 PM
Bartlett 914 Before committing to glue, I would make sure the h... Sep 10 2019, 12:09 PM
amfab I used the 3M Panel bonding adhesive for this, its... Sep 10 2019, 02:10 PM
bbrock All, Thanks for the suggestions. Let me explain ... Sep 10 2019, 03:14 PM
Jeff Hail If you are going to use anything use anti-flutter ... Sep 11 2019, 08:09 AM
bbrock Thanks Jeff and Andrew. I had never heard of anit... Sep 11 2019, 08:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:11 PM |
