| bbrock |
Sep 8 2019, 06:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Doing a bit of rehab on my front trunk lid in preparation for paint. One side of the A-frame member is stuck tight to the skin but the other side has lifted off about 3/32". I want to glue the lifted side down but don't know what adhesive would work best. 3M Panel Bonding Adhesive looks like it would be the ultimate but kind of expensive and probably overkill for this application. Any suggestions?
| Bartlett 914 |
Sep 10 2019, 12:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Before committing to glue, I would make sure the hood fits and aligns properly. I had a hood painted and found that it had been hit and the hood did not fit properly. i was able to spring it back enough to lay flat. Once you glue it, that may be difficult. There may be a reason the gap is there (as in the case of a bent hood)
bbrock Gluing trunk/frunk skins to frame Sep 8 2019, 06:18 PM
raynekat I would think any kind of "2 part" epoxy... Sep 8 2019, 07:24 PM
worn I never knew they were bonded there. Thanks. Mak... Sep 8 2019, 08:42 PM
bbrock
I never knew they were bonded there. Thanks. Ma... Sep 8 2019, 10:14 PM
bbrock I think I'm going to pick up a tube of this 3M... Sep 10 2019, 08:41 AM
Garland Try this stuff it loves 914 Sep 10 2019, 09:05 AM
bbrock
I need to actually ... Sep 10 2019, 09:08 AM
burton73 Brent buddy,
You need to think this out. The heat... Sep 10 2019, 09:59 AM
Garland
Brent buddy,
You need to think this out. The hea... Sep 10 2019, 12:00 PM
SirAndy :welder: Sep 10 2019, 12:07 PM
amfab I used the 3M Panel bonding adhesive for this, its... Sep 10 2019, 02:10 PM
bbrock All, Thanks for the suggestions. Let me explain ... Sep 10 2019, 03:14 PM
Jeff Hail If you are going to use anything use anti-flutter ... Sep 11 2019, 08:09 AM
bbrock Thanks Jeff and Andrew. I had never heard of anit... Sep 11 2019, 08:52 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:11 PM |
