| bbrock |
Sep 8 2019, 06:18 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
Doing a bit of rehab on my front trunk lid in preparation for paint. One side of the A-frame member is stuck tight to the skin but the other side has lifted off about 3/32". I want to glue the lifted side down but don't know what adhesive would work best. 3M Panel Bonding Adhesive looks like it would be the ultimate but kind of expensive and probably overkill for this application. Any suggestions?
| bbrock |
Sep 11 2019, 08:52 AM
Thanks Jeff and Andrew. I had never heard of anit-flutter foam and that looks pretty ideal, but also cost prohibitive for a one-off application like this.
After refreshing my memory on what Kent did in the link I posted above on Cairo's Six, I decided to follow his lead and clean out the old factory adhesive. Doing that was great because I was able to see exactly where the factory applied adhesive and what they used. The stuff I pulled out is clearly a butyl caulk, still tacky and stretchy in the parts where the frame hadn't separated. I ran a test with scrap metal and verified that cured 3M weatherstrip adhesive is pretty much identical in look, tackiness, and stretch. The foam would probably be the superior product to use, but the weatherstrip adhesive will be more economical and will very closely replicate the original factory treatment. Below is an updated image showing where the original adhesive was applied. Same as what Kent did but figured I'd post here in case someone stumbles on this in the future. The caulk was applied to the inner flange of the frame member only. (IMG:style_emoticons/default/beerchug.gif) ![]() |
bbrock Gluing trunk/frunk skins to frame Sep 8 2019, 06:18 PM
raynekat I would think any kind of "2 part" epoxy... Sep 8 2019, 07:24 PM
worn I never knew they were bonded there. Thanks. Mak... Sep 8 2019, 08:42 PM
bbrock
I never knew they were bonded there. Thanks. Ma... Sep 8 2019, 10:14 PM
bbrock I think I'm going to pick up a tube of this 3M... Sep 10 2019, 08:41 AM
Garland Try this stuff it loves 914 Sep 10 2019, 09:05 AM
bbrock
I need to actually ... Sep 10 2019, 09:08 AM
burton73 Brent buddy,
You need to think this out. The heat... Sep 10 2019, 09:59 AM
Garland
Brent buddy,
You need to think this out. The hea... Sep 10 2019, 12:00 PM
SirAndy :welder: Sep 10 2019, 12:07 PM
Bartlett 914 Before committing to glue, I would make sure the h... Sep 10 2019, 12:09 PM
amfab I used the 3M Panel bonding adhesive for this, its... Sep 10 2019, 02:10 PM
bbrock All, Thanks for the suggestions. Let me explain ... Sep 10 2019, 03:14 PM
Jeff Hail If you are going to use anything use anti-flutter ... Sep 11 2019, 08:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 06:12 PM |
