mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,614 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
So here is the deal.. Customer car has 4cyl with points and MSD box.
I remove the 4 cyl and put a -6 engine with pertronix in it. I re connect one of the cut wires from the msd box and do a resistance test.. All is good.. Engine runs funky with the MSD connected so I decide to run it with just the pertronix and disconnect the msd.. Engine runs great.. The harness was made by Perry and double checked everything and dont see any issues.. Also note the tach with the msd tach adapt is not accurate so assuming it is running 4cyl signal still? Any idea's? |
Retroracer |
Senior Member ![]() ![]() ![]() Group: Members Posts: 641 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest ![]() ![]() |
Ben - couple of things to try:
1) maybe the Petronix isn't triggering the MSD correctly - if you have an oscilloscope you can check the waveforms? failing that, drop in a set of points and wire to the MSD per instructions and see if the engine running improves 2) how does a timing light check on the crank pulley (or flywheel) look at lower revs? Consistent flashes or are there bogus or dropped flashes? 3) The MSD needs a solid GND and battery feed; these boxes demand high current at high revs. Make sure the supply isn't fed from tiny wires? - Tony |
Lo-Fi Version | Time is now: 1st August 2025 - 05:53 PM |
