Ratrod87 |
Member ![]() ![]() Group: Members Posts: 69 Joined: 4-September 19 From: Ft Mitchell Alabama Member No.: 23,429 Region Association: None ![]() |
Hello everyone , I've have been try to use the search engine to try to find some answers to my issue but I can't seem to come up with what I need to know. I apologise for asking so many questions and Im really greatful for everyone's help . So my son recently changed the oil in the car and we haven't really driven it much before that, when the engine is cold (2.0 bus engine with hydraulic can so I've been told by PO) it has really high oil pressure around 80 psi but as the engine warms up it continues to drop the hotter it gets. At idol when at operating temperature it is around 20psi or less and increases with Rpm. Napa said I needed 20-50 motor oil . I've never had a Porsche or vw before so I'm not sure if this is normal. Do I need different oil? Someone said get rid of the hydraulic lifters. Any suggestions or knowledge would be greatly appreciated. Thanks Jerry h
Attached thumbnail(s) ![]() |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
The stock oil pressure idiot light turns on at somewhere between 2-4 psi pressure. Hot idle pressure is often 5-10 psi, especially as an engine gets tired. 20psi hot is fantastic.
Are you gauges hooked up? I can't see anything on your oil pressure gauge due to the glare. But your volt and oil temp meters are either unplugged or the car is off. Which means your oil pressure meter should also be reading 0. Zach |
Lo-Fi Version | Time is now: 1st July 2025 - 04:42 AM |
